Question about Necchi Sewing Machines
I am trying to add thread to bobbin and bobbin will not turn
  • Jimmie Sill Apr 09, 2015
    Hi sharon , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? If this isn't enough tell me the type and model.
    Top Expert:
  • Necchi Master
  • 52,123 Answers
You have to loosen the hand wheel on the right end for the bobbin wind to work
Posted on Apr 09, 2015
My bobbin thread breaks too much. How do I fix it.
Be sure you are using the correct bobbin for your machine. Even though it appears to fit the bobbin case, if it is the wrong bobbin, it could cause major headaches.
Try a different bobbin. Try different thread.
Also check that the bobbin thread is wound smoothly and turning the correct direction in the bobbin case. Make sure the thread is threaded through the bobbin tension properly.
AVOID old and inexpensive, bargain bin thread!
There could be a nick or burr somewhere that is catching the bobbin thread and breaking it.
Try loosening the bobbin tension a bit. It could be too tight, especially if the bobbin thread is pulling the upper thread down to the underside of the fabric.
There could also be something wrong with the bobbin case itself that may be resolved by trying a new bobbin case (or borrow one from a friend, etc.)
Dealing with Lower Thread Breaking Sewing
Bobbin Thread Breaking How to Loosen Bobbin Tension
Nov 10, 2016 | Sewing Machines
Won't catch bobbin thread
hi Shauna.
this is all i could find out from the internet.
Make sure the presser foot is up when seating the thread through the upper tension. Now, it's time to draw up your bobbin thread. Turn the hand wheel (TOWARDS YOU ONLY, never turn the hand wheel away from you) and hold the needle thread lightly. Tug on it as the needle goes down and then comes up again.
if this is off no help to you go to this link and see if its any good to you.
Frequently Asked Questions Singer Sewing
or this one.
Sewing Machines Won catch bobbin thread Google Search
Dec 13, 2017 | Sewing Machines
How do I add thread to the bobbin on Singer sewing machine 3114?
Your repair shop will have to fix the handwheel, but you can still wind your bobbin. UNTHREAD the machine completely, and take the needle out. Set up your thread to wind the bobbin, and push the winder over until it clicks. Wind your bobbin. I don't have a picture of your model; this is just standard.
Feb 23, 2015 | Singer Sewing Machines
4795do i get hand wheel to turn, stuck
YOU SHOULD TAKE YOUR BOBBIN AND BOBBIN CASE OUT AND THOROUGHLY CLEAN IT. BLOW IT OUT AND THEN USE A QTIP TO MAKE A FINAL CLEAN. ADD ONE DROP OF SEWING MACHINE OIL ON THE RACE (SMALL AREA THE BOBBIN CASE SETS ON TOP OF). MAKE SURE ALL OF THE THREAD IS CLEARED OUT. DON'T THREAD MACHINE YET!
TRY TO TURN THE WHEEL TOWARDS YOU. YOU MAY WANT TO REMOVE THE TOP AND BOTTOM TO PLACE OIL ON ALL MOVING PARTS. REMEMBER THE NEEDLE ARM THAT GOES UP AND DOWN IN THE FRONT NEEDS TO BE OILED. THIS SHOULD WORK UNLESS THERE IS SOME SERIOUS PROBLEM.
Jan 23, 2015 | Sewing Machines
My bobbin won't move to add thread to it
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever?../
Feb 09, 2014 | Brother CS-6000
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
Needle only moves a little and then beeps saying needle up when the peddle is pushed. Machine will not run.
Good day Po!!!
Sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble; >Do this;
1.Top tension to tight >loosen tension 1 turn
2.Machine improperly threaded >check threading
3.Thread twisted on guide post > "
4.Thread twisted out of tension > "
5.Take up spring bent or broken >Check action of spring
6.Thread jumped off pull off finger >Check threading
7.Needle bent or burred >new needle
8.Bad cone of thread >try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tension spring to tight >Loosen tension slightly
2.Bobbin threaded wrong >check threading
3.Bobbin wound to tight or uneven >try new bobbin
4.lint or thread on bobbin case >clean inside case
5.Lint or thread inside hook >clean inside hook
6.Bobbin case nicked bent or burred >check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred >change
2.Needle set in crooked >Check
3.Thread jumped off take up spring >check threading
4.Thread jumped off pull off finger >check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth >Tighten bobbin tension
or loosen top tension.
2.forming loops on bottom of cloth >Tighten top tension
3.Bobbin placed in case incorrectly >remove and replace
4.Bobbin thread slipped from under >check threading of
tension >bobbin case
5.Lint or thread in top tension >clean between tension discs
Please just add a comment if you did not solve your problem by doing these procedures.
If this solution helps you please do not forget to testify and rate me...Thank you so much for using fixya!!
Jul 08, 2011 | Husqvarna Viking 1
Singer 57817 thread tension problem
If you have Increased the upper thread tension on your machine, try these solutions.
* Decrease your bobbin tension if your sewing machine allows you to adjust it. Consult your manual.
* Re-thread your bobbin, It may be threaded incorrectly.
* Reinsert your bobbin, It may be inserted incorrectly.
* Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both.
I hope this helps.
Sep 21, 2009 | Singer 57817 Computerized Sewing Machine
Bobbin problem: Huskystar by Husqvarna Viking E10 sewing machine
This has happened to me, even though I have been sewing for 30 yrs. When I take the bobbin holder out I realise what I have done wrong. When placing a bobbin into the bobbin holder the thread must be running around the bobbin CLOCKWISE. If incorrect take bobbin out of holder turn it over, so now the thread will run clockwise.If bobbin placed in holder and thread runs anti-clockwise, when you tried to turn wheel to bring bobbin thread up, it will either not do it at all or will make a huge tangle of the threads. Happy Sewing
Nov 17, 2007 | Sewing Machines
Sewing Machines Logo
64 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
