Is there something I am doing wrong to turn on the electronic panel. I press it on and hit set and it will not remain on.
  • Televison & ... Master
  • 681 Answers
Hi Francine,
You are not doing anything wrong. Your tv is going in protection mode every time you switch it on. Please consult someone who can handle your set.
Good luck.
Posted on Apr 09, 2015
How to start my dish washer
Check that the fuse or breaker for the DW is not blown or tripped. If not then likely you have a blown pump motor or something wrong with the panel electronics that fails to start your DW.
Feb 01, 2015 | Cars & Trucks
The power comes on but the picture and sound wont come on
No matter what the brand or model, if it does not come on, something electrical or electronic has failed. The only person who can fix it is someone who understands how to and that endlessly pressing the "on" button of something that has failed, will never change a thing.
This is an exercise in mind control........I must face the fact that I will have to pay something to find out what is wrong and whether it is worth fixing, because not a soul on this earth can simply assume as to what the cause of the problem might be.
Sep 07, 2014 | Insignia IS-LCDTV32 32 in. Television
PROGRAM PHILIPS MAGNAVOX REM-350 TO A TOSHIBA MODEL CE27C15
turn on the electronic item you wish to program
hit the button for the electronic you are trying to program, then press and hold the set button until it blinks twice. type 991 and you should notice indicator lit blinking on and off. when the electronic you are trying program shuts off, hit the enter button and then the set button
Jan 18, 2013 | Philips Magnavox REM-350 Remote Control
Toshiba portege r600 wont boot
Your BIOS settings may be wrong, or there may be a problem with the motherboard of the system.
I would check the BIOS settings on the laptop first.
When you first turn on the laptop - you might see something that says something like "Press F2 to enter Setup" or "Press Del to enter Bios" or "Press F1 to enter Setup" - or something along those lines. You will want to hit whichever key it is specifying and try to get into the BIOS/Setup.
Once you are in the BIOS, look for an option to restore defaults or reset factory settings. Do that and then save the changes and restart the computer.
If resetting the BIOS doesn't help, make sure that when you turn the computer on you are not plugged into a network cable at all.
If the system still gives the PXE error - then it is likely that something has gone wrong with your laptop motherboard. Unfortunately to get that fixed - you'll need to take it to a computer repair shop.
I hope that you can get the BIOS reset and it works for you though!
Nov 16, 2011 | Toshiba Computers & Internet
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
When i turn my tv on the sound comes on but no screen whats wronge with it ?37722hd techwood tv
Turn on set. press a bright flashlight against the screen. Look at the edge and see if you can see an image moving. Then the video is getting to the screen. You just need the backlight to see it.
If this set is under warranty, take it back to let them repair it for free.
If not then you will need to replace the backlight inverter board(s).
I think this set has two inverters. (master/slave)
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(replacing boards ) or have a friend with knowledge/skill you can fix it.
You can search for the inverter from several sources.
eBay
https://www.lcdtvparts.co.uk
and other sites
The board(s) will look something like;
Mar 01, 2011 | Televison & Video
Keys have changed
Your keyboard language is set to the wrong language.
Im guessing that as US is the default you are in the UK but using a US language layout for your keyboard.
Goto Start --> Settings --> Control Panel
Select 'Regional and Language Settings' (If xp you may need to set it to view in classic mode)
Select the 'Languages' Tab and click Details in the 'Text Services and input languages' group box.
Set the language there that you need and hit apply!
I got this from a local advice board. It should help you.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 29, 2009 | Logitech EX100 967499-0403 Keyboard
Keyboard is messed up
Try looking here to see if any of the keys are set wrong.
Normal 0 If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
Hope this helps. Bud
Dec 14, 2008 | Saitek Eclipse (PZ30AUR) Keyboard
Front panel timer/stand by blinking light
did you clear the code by hitting display channel 5 volume up then power then press 8 enter or look at sony blinking codes to reset to factory settings
Sep 10, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
