Question about Refrigerators
Why is there a layer of ice under the freezer draw
  • 998 Answers
Seems like the drain trough is blocked and overflowing. When the freezer defrosts, water is supposed to run into the trough and then outside to a evaporation tank or dish on the outside. Sometimes bits of food, especially peas and beans etc, fall out and then end up in the drain. You may have to remove the back panel from the inside of the freezer to get to it. The drain trough is across the bottom of the freezer at the back.
Posted on Apr 09, 2015
Why Ice under freezer compatment
check thermistors and cold control thermostat
Aug 22, 2014 | Samsung RF4287HARS Stainless Steel French...
My Bosch KGU3420GB fridge freezer keeps getting a thick layer of ice in the bottom of the freezer which then 'welds' itself to the bottom freezer draw. Any idea how to fix this?
Sounds like the drain is blocked and defrost water is collecting in the base. Try a full defrost and check the drain hole clears.
Apr 23, 2012 | Refrigerators
Fridgidaire freezer will not freeze, it will freeze a very thin layer of ice when I placed a cup of water in the freezer. I also cut it off over night to make sure there was no ice build up on the coils...
there is a chance that the unit is low on freon.
but you need to have the current draw check to make sure it is working in the proper range 1.2 to 1.6 amps while running
Aug 30, 2010 | Frigidaire Freezers
Thin layer of ice on the floor of my whirlpool top mounted freeze
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 12, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
I have a bosch frost free fidge freezer. I have noticed that there is a layer of ice under the bottom of the bottom drawer in the freezer. What is causing it? Thanks
defrost drain is blocked probably with ice
remove back panel inside freezer and drain is at bottom. melt of any ice with a hairdryer and follow up with hot water till water flows away freely. needs patience
Sep 07, 2008 | Bosch Refrigerators
LG frost free fridge freezer GR-359sq
defrost drain is blocked - probably with ice. take the back panel off inside the freezer and melt the ice off with a hairdryer then follow up with hot water till it flows away freely. this takes some patience. if fault reoccurs then get back to me
Aug 27, 2008 | Freezers
Layer of ice on the bottom of the freezer
one of two things is happening,your drain is clogged and is filling up with defrost water or your defrost heater is bad,remove freezer back panel,locate drain if frozen melt with hair dryer and use hanger or shop vac to clear it out,be careful not to melt freezer plastic,two bad heater,look at the heater to see if you have any blown out spots on it.also you can remove both leads to heater and check with omns meter,if you don''t get a reading heater is bad ,replace,hope this helps,thanks-mike
Jun 01, 2008 | Viking DFBB363 Bottom Freezer Refrigerator
Layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
Jan 20, 2008 | Freezers
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
