Question about JVC Audio Players & Recorders
I just picked up a JVC r33 receiver. Only three speakers work both left and right B speakers work. And only the left A speaker works. IS there a web site to trouble shoot?
  • 960 Answers
Try one of the speakers that you know works in the left B to see if it works. If it does, then you know you have 1 dud speaker which could be only a broken wire or bad connection. If the good speaker doesn't work, try checking all the connections and balance positions to see if the speaker left B output is actually set correctly.
Posted on Apr 09, 2015
  • Joe Tru Apr 09, 2015
    Thank you for taking time and proving info. I did indeed do the testing you have recommended. I even removed the dust cover and tested from the internal speaker post pegs within the electronic board.
    I wasn't sure if something within this curcit board could be tested and repaired.
gpgab97
  • 77 Answers
SOURCE: Only one speaker working on my str-de675 receiver
If the speakers themselves work fine, then the problem lies within the amplifier output. The channels can go bad after hard use, they can be repaired but it may well exceed the cost of the amp if it is not just one channel. Also be sure that you are hooking up speakers that are rated for your amplifier by matching the OHM resistance of the amplifier to compatible speakers.
Posted on May 03, 2009
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
SOURCE: Speaker Detect error Left Rear
Hey there.
I had the same problem until i figured out that if u dont have surround speakers connected it will be a error when trying to configure the rear surround speakers.
So if u are running a 5.1 system and have hooked up ur surround speakers to the back surround speaker port u have to change them to the surround speaker port.
Hope this work for u
Posted on Sep 09, 2009
In my JVC RX 8SD only works a channel. How do I repair this defect?
Start with the simple things.
  • Check left right balance
  • Swap output speakers left to right
  • Swap the speakers at the receiver to make sure no wire open/short
  • Swap input RCA cables left to right red/white - white/red
Ok No JOY!
JVC has thermal overload circuits/overload on most of there Amps.
Remove power for a minute or two to see if there is a reset.
Rewire speaker connections to speaker set 2.
Connect REC out to Rec In swap cables and see if problem is in pre-amp or power amp.
Check internal fuses.
Jan 19, 2016 | JVC Audio Players & Recorders
My left channel in my JVC RX-305 isn't working...what do I do to fix it? When I either push the volume up or down it makes a clicking sound. It was working just fine last night. My right channel is...
Try swapping the speakers or just check the left connections WITH POWER OFF. Disconnect the left speaker completely and see if the clicking stops.
Sep 05, 2011 | JVC RX-618V Receiver
RIght speaker not working in speaker system. Switching the left with right speaker make the right speaker work (not speaker) Plugging the 2 RCA into a different input changes nothing. 2 rear speakers...
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Jan 17, 2011 | JVC Audio Players & Recorders
My right speaker is no longer working. I have an
This could be as simple as a bad connection or more derastic like defective output transistors. Without looking at the unit and taking measuerments, it is impossible to say. As silly as this sounds, make sure you didn't hit the balance control all the way to the left. If not that, then I would suggest getting a detailed repair estimate from a servicer. Report the results of that estimate here and we should be able to walk you through the actual repair.
Dan
Oct 21, 2009 | JVC Audio Players & Recorders
My JVC receiver won't play my left front speaker. The right one seems to work fine but when I plug in the left it is virtually silent. i too have had a few "overload" incidents and am running two JBL 8...
swap the wires around to see if the right speaker will give sound on the left channel. If it does, the it's a blown left speaker. If you don't get sound out the right one either, then the left channel ouput has a bad capacitor somewhere in it.
Jul 06, 2009 | JVC RX-6010V Receiver
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
May 31, 2009 | JVC Car Audio & Video
No sound from all speakers except front left and front right
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Jan 24, 2009 | JVC TH-G30 Theater System
May 01, 2007 | Onkyo HTR500 Receiver
101 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
