Question about Viking DDB325SS Dishwasher
I have a "motor control status error" on my Viking Dishwasher. Any idea what this error message could be? The cycle cuts off shortly after the machine starts. Please help. model: ddb325ss
It also means never buy Viking! Kidding aside, we have been so frustrated with the poor quality of ALL the Viking D3 appliances that we forced the distributor to extend our warranty for another 5 years!
You might want to do the same cause if you have large followers on Social Media and Twitter, these companies don't want you to share your experience with their brand.
Posted on Nov 09, 2015
    Top Expert:
  • Viking Master
  • 42,828 Answers
It means call a repair man
Posted on Apr 08, 2015
Dishwasher Repair
get in touch with the retailer
Oct 19, 2014 | Viking Dishwashers
Cycle control lights flashing all at same time
are you sure you have cleaned all the water outlets as when these get blocked and the water builds up the dishwash will go into a standby mode as a sefety precaution to stop your kitchen getting flooded if it was me i would take off all water outlet pipes and use boiling water and a good cleaning fluid it only takes a little blockage and then it will cut off so clean all pipes through properly and then try again is the water going into the dish washer before it cuts off or is their no water going into it either if you post back ill have a nother look for you hope this is some help i had same prob with mine but it was different brand of washer but after cleaning all pipes inlet and outlet it worked fine and is still working now use good limescale remover cause if you live in hard water area then this is probably you problem .......................................................
Nov 10, 2007 | Viking 24 in. Professional Series DFUD140...
Oh my gosh, repairman made things much worse. Initially I was getting the HUBA disconnect error code on my Viking VDB325ss dishwasher. There was a moldy smell after each cycle, but at least the machine...
actually , call your local viking distributor and request parts to fix the unit and rebuild the dw to a vdb325e, software will remedy your situation. electronics are under a 5 yr parts warranty.
Sep 28, 2013 | Washing Machines
I have a dfb450 viking dishwasher that shuts off mid cycle or it wont start
Sounds like the timer is off. If this unit is under warranty I suggest calling service department. FYI viking has been putting out defective units
Jul 09, 2011 | Viking Dishwashers
My Viking DFUD042 is stuck in drain cycle while fresh water is entering the dishwasher through the grid on the right side. The pump is working continuously and it only stops after I turn off the power. ...
Hi, this could be a bad control board or a bad motor. It uses the same motor to wash as to drain. It just changes the direction of the motor in order to switch from drain to wash.
You'll need to run a cycle and you will need a multimeter to check which one needs to be replaced. Remove the kick panel and check the grey wire to the ground wire when it should be washing. If you have 120 volts, you need to order and replace your control board. Otherwise, if you don't have power and it's still draining, you need to order and replace the motor.
Jun 23, 2011 | Viking DFUD042 Built-in Dishwasher
The dishwasher will start to cycle. I can hear the water begin to run. I hear a click and at the time the dishwasher should start to run the cleaning cycle. During the cleaning cycle the dishwasher will...
This is probably okay, you have clock like motions running the motor electric contacts. There needs to be a delay between some cycles or shorting will occur. The motor on some designs, for example. is reversed to pump out water. to have this work long term, a delay is inherent and not a concern.
Sep 17, 2010 | Viking 24 in. Professional Series VUD040...
When I start the dishwasher it seems like the motor hums,water comes on but then it stops. When I open the door the control panel is flashing pots and pans and heavy when I had selected normal for the...
Pl refer user manual. In general flashing light may mean : no water flow, salt chamber empty, door not closed etc. It all depends on the error code message designed.assigned by the manufacturer.
Apr 30, 2010 | Viking DFUD142D Built-in Dishwasher
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
E6
I had this problem and fixed it tonight. When selecting a program water pumps into the machine, but with no drain i ended up with too much water and error code E6.
I traced the fault to a broken wire between the electronic module in the door and the pump. The point at which the door opens and closes on the cables had frayed the insulation and broken through the wire. As this was the live feed to the pump and a potential short from 240VAC to the chassis its dangerous!!
Repairing the wire break and re-insulating fixed the problem.
Lee
Dec 10, 2007 | Smeg DWI614 Built-in Dishwasher
Washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Nov 22, 2006 | Viking 24 in. Professional Series VUD040...
Viking DDB325SS Dishwasher Logo
142 people viewed this question
Top Viking Dishwashers Experts
Mike
Don Kahr
Don Kahr
Level 1 Expert
Rick Gloria Malmoe
Rick Gloria Malmoe
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
