Question about Haier Dryers
I set setting on my haier super capacity electric dryer it lights all up but then I press the start button the lights flash a minute & then you hear a CLICK sound in the knob panel & it goes off.
    Top Expert:
  • Haier Master
  • 46,272 Answers
Call a repairman
Posted on Apr 08, 2015
  • 14 Answers
SOURCE: kenmore 90 series electric dryer
check the door swithch first.. won't start if its shot....
tthen look to motor start relay...??
Posted on Jun 13, 2008
Illeagle
  • 525 Answers
SOURCE: I have a Maytag Neptune
This is your complaint;
"I have a Maytag Neptune MDE4000AYW Dryer. The internal light is on but the control panel will not start the dryer. The breaker did not trip, i have full electricity to the dryer. My settings work but will not preform when i press the start button. Is this an internal electrical problem? Can i fix this myself?"
Thank you for providing a valid make and model number!
Tip: A volt-ohm meter is a valuable tool for diagnosing problems.
My Solution:
!. Sometimes a breaker will only trip 1 side of the 2 sided breaker. Reset the breaker by flipping it off then back on to remove any doubt!
Note: This is not 100% positive, as a breaker can fail on 1/2 the sides, so you will need a meter to test voltage, if you have ruled all else out.
2. Sometimes a thermal fuse in the dryer will open due to a venting issue. The fuse is mounted on the blower housing
or on the element tube. See links for part diagram: http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516650&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1660&PPStack=1
See this link for diassembly procedures:
http://www.repairclinic.com/0100_18.asp
Inspect your vent thouroughly for obstructions. Also, inspect your lint filter if you use fabric sheets, by holding the filter flat under running water. If the water beads up and does not strain through the filter screen, replace the filter and avoid using fabric sheets.
3. The door switch may have failed, see link for part diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46718, See item no.6.
4.Wiring: The wiring at the dryer terminal block may have burned up. See link for diagram:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516193&PPStack=1
5. Push to start switch failure. See link below:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1033496&PPStack=1
In an effort to improve my quality of answers, please show your appreciation by rating the effectiveness of my answer.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 16, 2008
myob247
  • 1342 Answers
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
Possible causes for your issue include:
Blown fuse
Timer or motor inoperative
Housing wiring not properly connected to dryer
Bad door switch
Faulty "Push to Start" switch
It would probably be best to have a professional pinpoint the exact defect.
Click Here for a very good source of information on Maytag dryers
Posted on Jul 17, 2008
vickygomar
  • 460 Answers
SOURCE: I have an older model Kenmore electric dryer 80
I hope this information will help U
http://repair2000.com/norun.html
was this helpful?
Posted on May 13, 2009
  • 15 Answers
SOURCE: dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Posted on Jul 20, 2009
I CHANGED DRUM SUPPORT ROLLERS AND PUT BACK TOGETHER AN IT WILL NOT START
Suggest the following.
  • Check drum light. No light defective door switch. Light yes one leg of 220 circuit OK.
  • Be very sure motor doesn't start when you set to run. Belt may be off the motor and motor is very quite. Fix belt. Motor may be stuck or failed listen to hear if it is buzzing
  • When pressing start button listen for distinctive run relay activation. If when the start button is depressed I would expect to here the relay.
  • Motor run circuit relatively simple. The drum motor and blower are one assembly.
Nov 30, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The control button on the Whirlpool Duet Dryer is permanently on. As a result, we are not able to start up dryer. We have unplug dryer for 5 minutes with no positive results. We have also tried holding...
Hi
Press and hold the CYCLE SIGNAL/END OF CYCLE button for 10 seconds to unlock the controls. Hope this helps...please post back for further assistance.
Daniel
Jun 11, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The control panel red light is on: Control Locked" and dryer won't start what should I do?
While the machine is on press "end of cycle" for 3 seconds. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
How abt a nice rating for the free help? Thnks
Jun 02, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer wont start when start button is pressed, but humming sound
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
213 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Haier Dryer Expert? Answer questions, earn points and help others
