Question about Refrigerators
What is the best setting for the freezer. The settings range from 1 to 4. Second hand give away no instructions
It came set on 3 but I don't know if that is warmer or colder than 1
    Top Expert:
  • Refrigerators Master
  • 44,379 Answers
With freezers the higher the number the colder the setting
with fidges the higher the number the warmer the fridge.
Posted on Apr 08, 2015
  • Vincent Carbonaro
    Vincent Carbonaro Apr 09, 2015
    Excellent thak you I had an idea it was the reverse to fridges but wasn't sure
  • 5,323 Answers
The medium settings"
Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Testimonial: "Thank you excellent information"
What setting should my chest freezer be on 1-5 ?
freezers settings is 1 is cold , 5 is very cold
Apr 22, 2017 | The Computers & Internet
I need to know how to set a h005 haffstreuner watch after battery change
This is for the HA005:
B) SETTING THE TIME
1. Pull the crown out to the 2nd position.
2. Turn the crown to set hour and minute hands.
3. When the crown is pushed back to the normal position, small second hand begins to run.
C) SETTING THE DATE
1. Pull the crown out to the 1st position.
2. Turn the crown clockwise to set the date.
*If the date is set between the hours of around 9:00 PM and 1:00 AM, the date may not change on
the following day.
3. After the date has been set, push the crown back to the normal position.
E) CHRONOGRAPH RESET (INCL. AFTER REPLACING BATTERY)
This procedure shoud be performed when the chronograph second hand does not return to zero position
after the chronograph has been reset, and including after the battery has been replaced.
2. Press button "A" to set the chronograph second hand to the zero position. The chronograph hand can
be advanced rapidly by continuously pressing button "A".
3. Once the hand have been zeroed, return the crown to the normal position.
* Do not push crown to normal position while the chronograph second hand returns to zero position.It
stops on the way when crown are returned to normal position and its position is recognized as zero
position.
May 25, 2014 | Hitachi HA00593 Power Supply
Fridge not cold enough
The higher the number the colder the temp is supposed to be.
In order to prevent the formation of bacteria and other such organisms to affect food the way it does, the ideal temperature range of refrigerators has been mentioned here. Before we look at these settings, it is important to know the format in which temperatures are represented within a refrigerator. Commonly, you will notice a dial representing the figures 1-5 or 1-9 in the refrigerator, and a dial representing the letters A-E in the freezer. The ideal setting is usually in the middle of such figures.
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 degrees F - 38 degrees F or 1 degrees C - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrees C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Belling Refrigerators
Temperature of thermo defrost samsung
The ideal temperature in the refrigerator ranges between 34 - 38 degrees F or 1 - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrress C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower. See more at:
Mar 01, 2014 | Refrigerators
I cannot locate my owners manual for my Imperial upright commercial freezer. I need to know how to defrost it
Hi the following should tell you all the info about the controller
Directions for Accessing and Setting G3 Series Digital Controllers
Changing the Temperature
Instructions for changing the desired temperature
1) First, press set for 1 second
The current set value will begin flashing after a few moments
2) Second, increase or decrease the temperature value by using the up or down icons
3) Lastly, press set to confirm the new value
Manually Setting Defrost
Instructions for manually setting automatic defrost
1) Press down the snowflake icon for more than three seconds
note that defrost will only begin if the temperature inside is equal to or less than 45
degree F.
2) Defrost will last about 25 minutes and then return to normal cooling or freezing
cycles.
Using Flash Cooling or Freezing
Instructions for Using the Flash Cooling or Freezing command
1) First, press the up and down icons together for more than 3 seconds
2) The refrigeration unit will immediately begin cycling to quickly reach the desired
temperature set point.
3) ** Flash Cooling/Freezing Option must be first set on the Configuration Parameters
Menu: Go to CC (continuous cycle duration) and enter a value. The value entered will
be the amount of time (in hours) the Compressor will run continuously to pull the
temperature down. Note: Flash Cooling may go below the temperature set point.
Eg. CC = 2 = 2 hours of Flash Cooling/Freezing.
Accessing & Setting Configuration Parameters
Instructions for Accessing & Setting Configuration Parameters
1) First, press set for 3 seconds, the display will show PS, then press set again.
2) Next, enter the password #22 to go the menu, press set.
3) You can scroll within the menu by pressing the up or down icon.
4) Go to the Carel controller detailed menu chart for specific controller settings. Click
Here.
5) To change the values, go to the menu listings ( C0, C1, D0, D1, F0, F1 etc), press
Set, the up or down icon, then Set again to complete the changes.
6) Finally, to Save all the changes made in the Menu, press and hold Set for 3 seconds.
Note: One of the parameter menu listings must be accessed to Save properly by
pressing set for 3 seconds. Saving by pressing Set for 3 seconds outside of the
parameter menu listings (ie, CO, C1, DO, D1, etc) will not save the changes.
7) If you do not want to Save the changes made, do not press the buttons for 60 secs
Regards
Gordon
Apr 22, 2011 | Migali Imperial Series Aluminum Reach In...
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Kenmore upright freezer
1)forget about the key you'll be disposing of this unit anyway
2)the alarm is to tell you that the unit is above ideal temp.
3)the unit isn't making temp due to refrigeration issue. if it isn't cold enough on 3 then 1 won't do it either.
Apr 09, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
