Question about Dishwashers
Too much soap being dispensed - Dishwashers
    Top Expert:
  • Dishwashers Master
  • 46,605 Answers
Good answer
more is never better and liquid detergent is better still than powder.
Posted on Apr 08, 2015
    Top Expert:
  • 47,651 Answers
Then use less to begin with .
Why does soap dispenser just barely dispense soap?
If you are using soap instead of dishwasher detergent, the dispenser probably is clogged.
Mar 30, 2016 | Dishwashers
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
Steam Vac Is Not Dispensing Soap
Try using a rubber tipped air nozzle and compressed air at the end of the soap dispenser line. Brief intermittent blasts of air should take care of it.
Nov 16, 2013 | Hoover F6212-900 / F6215-900 SteamVac...
How do you open brighton professional hand soap dispenser to refill
OUR BRIGHTON TOUCH FREE BLACK 700 ML HAND SOAP DISPENSER WILL NOT DISPENSE THE SOAP
Aug 14, 2013 | Brighton Professional LTX-12 Hand Soap...
Soap despenser+will not dispense soap.
Hi. WHen a soap dispenser will not dispense soap it is generally because of one of two things. Either it is clogged or the soap you are dispensing is too thick and needs to be diluted a little with water, or possibly both. J.
Aug 07, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
Won't dispense soap. Changed batteries twice,
Sometime the viscosity of the soap could be the culprit. If you had changed to a thicker soap sometimes those pumps can't handle it. Try a less viscous soap and lets see what happens. Good Luck PAL
Jul 26, 2010 | NRS iTouchless Stainless Steel Automatic...
My grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
Apr 01, 2010 | Grohe Satin Nickel Soap Dispenser...
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Soap dispenser pump pricefister
Here is the link to installing a Price Pfister Soap dispenser:
Soap Dispenser
Hope this helps!
Nov 23, 2008 | Price Pfister Home
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
