Question about Weber Grilling
I have a 15 year old weber grill silver series. The igniter does not work is there a battery below the push switch if so how do I get the old battery out
  • 15,729 Answers
Replace the igniter. The device uses piezo electric theory and it has no battery.
Posted on Apr 08, 2015
SOURCE: changing the ignition on my weber grill
I just changed mine last week. I used a wrench underneath to turn it -- it was held on by a couple of plastic anchors. As I turned, it broke one off and freed up the piece so that it could be moved and pulled thru the opening. You really can't hurt it since you are replacing it so give it a yank or two -- the new one went in just fine.
Posted on Mar 30, 2009
SOURCE: Can I replace the thermometer on my Weber Genesis
Lightly tap on the pointy end of the thermometer, and it should snap out of the bracket that holds it. Snap replacement into position...
Posted on Jun 26, 2009
SOURCE: Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Posted on Apr 30, 2010
SOURCE: Gas is not moving from tank to Weber silver grill
  1. you need to shut off all the valves and disconnect the tank.
  2. slowly open the tank valve and listen for gas escaping. (DO NOT ATTEMPT TO SMELL FOR THE GAS, THIS COULD PROVE HARMFUL TO YOUR HEALTH)
  3. you are looking for a valve or connection that is clogged. if gas escapes from the tank the reconnect the tank and check at each connection.
  4. if all connections are complete and functional, your problem may be at the burner itself. Using a push pin, **** the holes in the burner, paying attention to the amount of greasy build up.
  5. If the level of build up is severe, remove the burners completely and soak them in a tub of concentrated dish soap and warm water. DO not use hot or cold water.
  6. remember to shut the tank valve off in between each test cycle.
  7. a clean grill is the key to keeping it functioning properly,
  8. if you are having trouble getting the burners out, spray lighter fluid on the burners holes and light with a fireplace match, or rolled piece of paper.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Posted on May 03, 2010
SOURCE: How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
Posted on Jun 13, 2010
What model rotisserie will fit a Weber Silver B 250000 model gas grill
You need the Genesis E/S-series rotisserie. It is part # 7519 and can be located at the page below:
Genesis E/S series Rotisserie
Sep 14, 2011 | Weber Genesis Silver B Grill
My electric start button will not spark when pushing down, the grill is only one year old.
The issue might just be that the battery powering the starter is dead. There should be a small compartment where there is a small battery stored. Change out that battery as well as making sure all of the wires from the battery to the button to the lighter are all connected well.
Hope that helps!
May 11, 2011 | Weber Summit Silver B Grill
Have a 15 year old Weber Genesis. Recently filled the tank, and was working fine. Today, went to fire it up and barely any flame coming out of the burners. In fact, when I turn on the middle burner, the...
You need to completely change the grill because it's been there for over 15years and alot of rust and linkages will after affected the grill from working properly well.The best bet is to get a new grill.
Nov 25, 2010 | Weber Genesis Silver B Grill
Rear Burner is hotter than the front burner on my Weber Grill
Since the grill is 15 years old, it is probably time to rebuild it. Replace both burners and anything else that is not working properly
Dec 20, 2009 | Weber Genesis Silver B Grill
The electronic ignition on my grill no longer sparks to ignite the gas. I replaced the battery and cleaned the contact points but there was not any improvement. Can the entire assembly be replaced?
Yes you can replace the entire assembly.
However you can try adjusting the spark gap to see if this will resolve the issue.
Heat will often expand the spark gap thus rendering a spark impossible.
Small adjustments and be careful not to break the ceramic insulator.
Many gas grills use a static ignitor that does not require a battery.
Big red button you push that causes a snapping noise. This makes a spark and lights the gas. These can last quite a long time and inexpensive too.
Oct 03, 2009 | Weber Genesis Silver C Grill
The igniter does not work. i changed the battery. it used to click when pressed down and pop up. now it does not. i do see that the spring is still in the unit.
I had horrible luck with my Weber igniter. They just don't seem to last. I replaced mine two or three times in the 10 years I had my grill, then finally gave up and started using a lighter. So, try replacing it with a Weber part, or one of the universal igniters at your favorite home improvement store.
Jul 25, 2009 | Weber Genesis Silver B Grill
My silver c igniter does not work..need to manually light..burners work..is new igniter worth pruchase? grill is almost 6 years old
yes replace it. you can call weber and they will send you one FREE just tell them whats wrong and the model number of the grill
Jul 18, 2009 | Weber Genesis Silver C Grill
May 21, 2009 | Weber Genesis Silver B Grill
Grilling Logo
168 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
