Need wiring help for control board
Elderly man replaced furnace motor but did not mark where the wiring harness wires go. Can you tell me what the orange and black wires go on the board?
  • 1 more comment
  • Brad Brown Apr 08, 2015
    What is the make and model of the furnace?
  • Diane S
    Diane S Apr 08, 2015
    Xenon model XF801155A with control by White-Rodgers 50T55-288. Only furnace still operates, a/c died few years back. Have motor brown wires going to capacitor, the blue wire goes to heat (should be medium speed). The yellow wire goes to CIR N (neutral maybe). two wires are parked (red and orange) which should be low and med-low speeds. The black wire he can not remember where it went- I suspect it went to cool but he said no.
  • Diane S
    If the black wire is for cool (which the diagram I found indicates black is high speed, then he may not need that connected to anything.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 39 Answers
Black is hi speed cool and orange is low speed heat
Posted on Apr 09, 2015
  • 182 Answers
SOURCE: replacing the thermostat, took the
the normal wiring for stats is white=w=heat,red=r=24volts,green=g=fan,blue=c=common,yellow=y=cooling.
see what ties into your furnace board and match the terminals.
Posted on Aug 12, 2008
  • 1214 Answers
SOURCE: Wiring a retrofit soft start blower into a Ruud 5T/100k gas pack
Chances are, you've smoked the motor. You basically put 120 volts across the speed windings of the motor when you did this.
What you need to do is, with the new motor, you will have neutral, and speed 1, speed 2, speed 3, etc. Hook one of the original black wires to neutral (it would be best to trace which of the two black wires is connected to neutral, and connect this one.).
Black on the new motor is probably High speed, red is probably low, orange is medium speed. Hook the remaining black wire to one of these, and no more than one of these, or you will smoke the motor again.
Attach a wire cap and/or electrical tape to the remaining wires to insulate them from contacting anything else.
Posted on Jan 27, 2009
  • 587 Answers
SOURCE: connecting a motor starting capacitor
New Capacitor
herm start on the compressor
fan start on fan motor
c run or power to both compressor and fan
Posted on Apr 25, 2009
  • 59 Answers
SOURCE: need som help with a
Look at the schematic on the inside panel of the cover you removed. It should have the schematic with the wires and colors labeled as to what goes where. The wires are a common, run and start wire. They schematic should identify the wire by color and motor connection by number. You should be able to see the numbers on the motor by the connection. hope this helps.
Posted on Jan 29, 2011
I need a wiring diagram to help install a Honeywell st9120c-4057 control board
SHOULD BE A WIRING DIAGRAM WITH THE NEW CONTROL THAT HAS CONVERSION CHART TELLING YOU EXACTLY HOW TO CONVERT OLD CONTROL TO NEW ONE . MUST BE LISTED ON PAPER EXACT CONTROL NUMBER IF IT DONT LIST IT YOU HAVE WRONG REPLACEMENT CONTROL BOARD.
Jan 11, 2014 | Honeywell Heating & Cooling
Pleasureway Traverse furnace fan runs when funace is off.
Bad/ stuck fan relay or temerature sensor is not shutting the fan off. Or there is a short on the low voltage fan control circuit. Check to see if the Green terminal is jumpered to the Red terminal at either the furnace control board of the 'stat, if not, ohm the wires with both ends off- I've seen installers accidently shoot a staple thru the wire and short the wires together more often than even I can believe! Hope this Helps! PS Some furnaces have fan switches inside the furnace- check for one and see if it's "on"- sounds too simple, but sometimes the "simplest" is the correct answer.
Mar 22, 2013 | Heating & Cooling
Need Part# 2568401(edge card) for a Goodman furnace, Model# GMP075-3
likely need to replace board. You may get it to work, but there is lots of data traveling in that harness, and ifn its noy
t replace, it will bite you. If your lucky the problem is in the end of the harness. Check both ends
Dec 21, 2012 | Heating & Cooling
I have a Lennox Diplomat furnace. How can I tell if the blower motor is set for high speed when it comes on?
The only way to really tell if the blower is set to high is to look at the control board inside the furnace and see how it is hooked up. You will have either a 3 speed or 4 speed blower motor, more than likely a 4. These are Hi, Med Hi, Med Low, Low. Each speed has its own color and if the motor has ever been changed, it could be different from factory diagrams. The most common colors/speeds are:
Black- Hi
Blue- Med Hi
Orange- Med Low
Red- Low
You could have different colors but they will be close. If it's an aftermarket motor, the speeds will be listed on the motor itself, but very difficult to get to sometimes. On the board, you should have terminals marked, COOL, HEAT, PARK, PARK. You hook what speed you want for Cool and Heat and put the other 1 or 2 wires on Park.
Again, these might not be exact, but these are the basics and they usually don't deviate from them to much unless it's a 95% furnace or such. If you do have the diagram for the furnace, you will be able to find everything with no problem now that you have the basics. Also keep in mind that you will have a Common wire from the motor that hooks to Com. terminals on the board. Hope this helps and good look!
Jun 19, 2012 | Heating & Cooling
Will not complete cycle..shows F11. This has been an ongoing problem, cannot get anyone to fix. What would you recommend? Would like to tell the world not to buy!
The F11 error code indicates a serial communication problem between the central control board and the motor control board. This can be caused by:
  • A loose or failed wire harness connection between the central control board and the motor control board.
  • A bad wire harness connection between the motor control board and the drive motor.
  • A failed drive motor.
  • A defective motor control board.
  • A failure in the central control board.
Jan 23, 2011 | KitchenAid KHWS01PMT Front Load Washer
My machine wach but do not spin a the end.
Note: This solution is intended only for asker qualityisc as per Live Chat session discussion. Error code reads E47 which means the Control board thinks the PTC circuit (wax motor) is open.
Unplug the machine then remove the spring-loaded wire loop that holds in place the front of the bellows over the lip of the door opening in the front panel.
Using needle nose pliers, start where the spring and wire are connected at the bottom of the bellows and pull the wire out of the groove of the bellows then pull the bellows off of the lip of the front panel.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine and disconnect the electrical connections.
Measure the resistance of the wax motor. The normal resistance is around 1500 ohms. Shorted or open circuit wax motor means the door lock and switch assembly needs to be replaced.
Simply
replace the door lock and switch assembly (part #131763202) if the wax motor reads shorted or open to address the issue. But if the wax motor resistance is normal, check the continuity of the door lock and switch assembly wire harness, particularly the wax motor wire harness. Start with the continuity of the red/black wire of the wax motor harness to each of the red/black wires of the door lock and switch assembly harness. They should all have continuity; otherwise, replace the harness.
Remove the top panel to access the control board if further continuity test is necessary or if the red/black wire of the wax motor harness has continuity with the all other red/black wires of the door lock and switch assembly harness.
Remove the screws attaching the top panel to the rear of the cabinet then lift the panel off. The console can be removed from the cabinet to completely access the control board connections, particularly the door lock and switch assembly harness connections. Check the continuity of the red/black wires at the door lock and switch assembly to the red/black wire of the harness connected to connector J2 on the control board.
The problem is in the control board if the wax motor is good and the door lock and switch assembly wire harness has all the necessary continuity. The only viable solution, should that be the case, is the replacement of the control board.
Oct 03, 2010 | Frigidaire GLTF2940ES Front Load Washer
Need wiring diagram for installation of an A.O. Smith DL1036 blower motor. Unsure is it is wired correctly. Wires provided are Black, Red, Yellow, and Blue.
These wire colors are the different speeds for the motor. You will have 1 wire going to the heat, 1 wire going to the cool, and 2 wires on the park terminals on the board if available. It will actually tell you the speeds of the colors provided on the motor itself i.e. BLACK=High and so on. Without knowing what model of unit you are working on, it's hard to say where exactly the wires will hook up, but the majority of the time you will have a electrical board inside the furnace and the terminals that I described will be marked. Hope this helps and good luck!
Aug 04, 2010 | Heating & Cooling
Outside ac unit operates but no blower. Fan "on" does not operate from thermostat. However "heat" works fine furnace and blower. ???
Go to furnace and shut off power, remove blower door compartment. Inside you will find a control board where thermostat wires are connected. Should look something like this:
R-Red Wire= Power
G-Green Wire= Fan
W-White Wire=Heat
Y=Yellow or Blue Wire=Cooling.
It sounds like you have a bad motor speed. So try this:
With Power Still Off, on the same control board there is a terminal usually marked Cool and Heat. There should also be a couple of terminals that are named park. The wires hooked to these are the fan wires..
Exchange the Heat and Cool wires on the terminal board. Put everything back together and try cooling again, if the fan comes on
then you have a burnt out motor speed. Go back to furnace and change
the heat and cool wires around, next if Cooling had the black wire hooked to it, put yellow or blue on Cooling and black to park.
Note: The reason why you put the blower door back on is because it
has a door switch that if not properly seated, you wont be able to power
up anything
Jun 22, 2010 | Heating & Cooling
How to change fan speed on a goodman gmp 100-3 furnace
Usually you can find the control board on the lower part of the furnace. Turn the power off and remove the
doors. This board is usually located directly in front of the blower motor.
On the control board locate the terminals marked heat/cool/park and Park Lets say the Heat Terminal
has a red wire attached to it and you want a higher
speed.
Red is uasually low speed, remover the red wire from
heat terminal and exchange it with a wire attached to
a terminal lab eled park. Black is usually high spped
Jan 01, 2010 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
