Question about Yard Man Garden
On 16.5 Yard Man when blades engage the fuse blows
    Habit-Forming:
  • 31 Answers
Do you have an electric PTO if you do ,it sounds like it's shorted out causing the fuse to blow. disconnect the plug in at the pto try engaging pto switch .Does fuse still blow? if not Its the PTO unit mounted on the crank shaft . replace.
Posted on Jan 01, 2018
  • 62 Answers
SOURCE: FUSE BLOWS WHEN BLADES ARE ENGAGED CRAFTSMAN MODEL # 917.27686
Most probably you have a wire shorting to the frame of your mower.
Trace (follow) the wires from the switch, checking for any frayed, burned, or bare wires.
Repair as needed.
Posted on Apr 17, 2009
wireguy212
  • 1627 Answers
SOURCE: snapper yard cruiser 33in. cut joystick blows
Unplug the engagement clutch[it bolts to the motors crank] and try to engage again.If the fuse does'nt blow you need a clutch.If it does still blow you need a switch or you have a short in the harness.
Posted on Nov 03, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
  • 146 Answers
SOURCE: Mower deck PTO switch will engage when pulled but stop when rele
The PTO switch has failed. There is an internal spring and plastic parts in toggle switches that keep them in the actuated position. It's not practical to take the switch apart to fix it, but replacement switches are readily available - probably $12 - $20. It's a good idea to disconnect the negative terminal from the battery before you do any electrical work. Be sure to put the wires on the corresponding terminals of the new switch. Good luck! Please rate if you find this helpful, thanks.
Posted on Jun 04, 2010
The mower starts but it keeps blowing the fuse when I engage the blades
check for a area of the wire insulation that has been wore off against the frame or body of the mower. sounds like a electrical short. it may be a very small spot that's all it takes so check well
Jul 09, 2014 | Husqvarna 23 Hp 48" Deck Yard Tractor
Blades will not turn on lawn mower
You haven't given enough information of the problem. The blades themselves wont turn when you try to spin them by hand or they wont turn when you engage them with the lever or the switch?
Jan 11, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Fuse blows when i engage blades on my bad boy ztr
Is the fuse a 15 if so there could be a short some where.
Oct 02, 2012 | Garden
I have a 46" Yard Man riding mower with 20 hp BS.
Hello, Ask your local Mower shop if they show a Thermal switch for the PTO. You may have to replace it or move it away from the heat.
Aug 14, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
2007 Husqvarna Riding mower blade will not engage when switch pulled out. Fuse blows & mower dies! Help!
Apr 25, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Snapper yard cruiser 33in. cut joystick blows
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I change the blades on a mtd yard-man 42" riding mower
u do not have to remove the deck. all u need is a floor jack and some air pressure because the bolts may be very tight u will needs either a 7/8 or 13/16 socket and they come off normal lefty loose righty tight. good luck
Jul 08, 2009 | Mtd Products Yard Machines 158CC Tiller
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
Top Yard Man Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Thomas Perkins
Thomas Perkins
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
