SOURCE: pool timer not working
http://intermatic.com/Default.asp?action=div&did=5
here is the link to intermatic, usually u take the pieces they give u and hold them up against the wheel and tighten the screw, at whatever time u wish for it to come on or go off, sometimes the trippers are different, this is just a generic answer, if its electronic its different. different brands are different.
have a good day
SOURCE: Do not know how to set the timer
Here's a link to a downloadable manual for the L12/871 or TE103 timer, if that's what you're looking for. Click here or here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: I have an old pool timer. How to set it?
yes there should be 2 tab on the wheel one for off one for on set the wheel to the correct time by pulling it up which is printed on the wheel. then set the tabs to your desired time.
SOURCE: timer won't turn off or on by itself
Pull the pin up wait and see if it comes on you will know then. Most do pull up but there are a few that have the pin that has to be shoved in. 90% however do have to be pulled up to set the timer for off and on.
Testimonial: "The problem was trying to decide if the pins up or down turned it on and off. I think I have it figured out now. UP (i think) makes it turn off & on."
SOURCE: Raindrip timer R672C
Problem for Raindrip R673CT Digital Water Timer Raindrip timer R672C I am trying to program the days of the week on this time and cannot do it. Can you help?
