Question about DISH Network Televison & Video
How do I reconnect my Dish Network DVR to my Seiki TV? It worked before but I unplugged the cables. I plugged the same cables in there was no yellow plug in. It says No Signal no matter what I do
  • 38 Answers
SOURCE: DVR won't turn on
Sounds like your power supply.
Posted on Nov 28, 2007
  • 374 Answers
SOURCE: combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Posted on Sep 23, 2008
  • 374 Answers
SOURCE: Dish Network "Blue" Smart Card upgrade... Now get only "015"
The solution is usually a simple one and that has been suggested already but I will ask you to try one thing first. Remove the new smartcard and do not put one in. If the receiver still displays a picture and yoou can get to menu 611 run a check switch. After this is performed cancel out of the screens and re insert the new smartcard. Once the system comes back up perform the same steps as you did before with the smart card removed. If this fails you can try the solution they offered which was to update the sofware. There is no reason your software should be outdated if you were using this receiver before the new smartcard but try anyway as it may SOMEHOW work. Using the remote turn the receiver itself off. Allow the receiver sometime to turn itself back on-this could take awhile so plan this when you leave for work or are going to be gone from the house for sometime so you do not get bored waiting for this to occur. If the receiver has not turned back on in 45 minutes or more then the receiver will either need replacing -which i suggest- or they will try to send you a new smartcard if you talk to Cust service. Tell them you want a service call to fix the receiver. While you have them on the phone verify your receiver number and the new smartcard number which is on the back of the card and ask them to send a hit to the receiver. If the receiver has not been associated with the new smartcard or if the smartcard was not loaded with all of your programmming this should fix the issue. Thanks for using Fix Ya.
Posted on Feb 27, 2009
  • 254 Answers
SOURCE: Dish VIP 622 constantly resetting
its a problem of faulty hard drive.but you will have to get iot checked at the local repair shop.or connecting the external hard drive to your machine.
Posted on Apr 04, 2009
  • 56 Answers
SOURCE: dvr not responding
There was a software update early this morning which caused your recvr to go to recovery mode until it downloads the new software which takes about 4 hours. Once this is done you should be just fine!
Posted on Dec 10, 2009
One for all universal remote I need the code to program my seiki tv
here you go
Product Support For One for All Remotes.
Q: I'm trying to set up my cable/satellite/universal remote to work with your television. What is the manufacturer's code for my SEIKI TV?
A: Cable and Satellite content providers control the remote codes, and we apologize for any confusion during the remote programming. Please try the following codes:
DIRECTV - 10178 11687, 10178, 10835, 10056, 10150, 10463, 10156, 11498, 11401, 0178,
Time Warner Cable - 0178
Philips - 0002
Comcast - 11864, 10178, 0060
Cox Communications - 0178
Atlas DVR Device URC - 0178
Bell Remotes & Dish Network - 505, 506, 516, 523, 526, 566, 573, 612, 627, 647, 652, 653, 654, 655, 656, 658, 659, 664, 665, 667, 669, 670, 679, 680, 704, 717, 730, 738
ATT U-verse - 1004
Hitachi - 0002
URC- 2964, 0145
Cablevision customer (optimum)- 004
Bose or universal remotes- LG remote code
Universal Remote - One For All OARC04G 4 Device Universal Remote (Element code)
These codes may not work on some universal remotes. If there is another code listed for SEIKI Digital in your universal remote control guide, please try that code. Refer to the Remote Control Guide under your TV's model number for more information.
Jan 09, 2017 | One For All Televison & Video
Dvr box wont record
Are you able to access any of your previous recordings?
Try unplugging the receiver for 10-15 seconds and plug back in. The receiver will reboot itself for you and should restore functionality of the DVR. If that doesn't work the hard drive has likely failed and we would need to send a replacement receiver.
Nick Franta
DISH Network Customer Service.
Jan 23, 2011 | DISH Network DVR-625 DTV Receiver /...
Sound isn't working when watching tv
Hello, Matt Gonzales with DISH Network here. To resolve this issue, try doing a hard reset on the receiver. To do a hard reset, you will unplug the receiver from the power outlet, leave it for 15 seconds, then plug it back in. After doing this, your receiver will go through a rebooting process which takes about 5 minutes. If that does not work, it can be a cabling issue, proper cabling diagrams can be found at tech.dishnetwork.com. If you're not able to get it working, please feel free to email me at matthew.gonzales@dishnetwork.com.
Dec 24, 2010 | DISH Network DVR-625 DTV Receiver /...
DVR not working. Says to unplug for a minute, I did multiple times, still not working
kuda08rdb,
Are you still having problems with your 625 receiver? It sounds like you are getting a 024 error message. When you unplug the receiver and plug back in, do you ever get a 311 error message? If you are still having problems, the receiver may need to be replaced. I would be happy to further assist you if you would respond back to this site.
Ray Calo
DISH Network
Sep 19, 2010 | DISH Network DVR-625 DTV Receiver /...
Light in the set box is not changing red light is flickering. Green light is not coming inspite of changing the batteries in the remote control. I am having Dish TV in my house.
Hi, this is Mary with Dish Network Customer Service. It sounds like you are experiencing a power issue with your Dish network VIP622 DVR. You can try resetting the Receiver box by unplugging it for 10 seconds (if it is plugged into a surge protector, for the purpose of troubleshooting, plug directly into a wall outlet). Wait for receiver to reacquire satellite signal. If you are still having an issue, you will need to contact Dish Network because the receiver box will probably need to be replaced. I hope this information helps you.
Sep 03, 2010 | DISH Network ViP622 DVR DTV Receiver /...
I have an LG 42LG70 42 in. HDTV LCD TV. Whenever I have my brightness setting below 40, my Dish DVR will no longer respond to its Dish issued remote control. If I turn the brightness anywhere above 40,...
Tries unplug,replug the DVR box an hour later.The box should reset itself and update it software.The box should work normal again.Not,call Dish Network to replaced the box,have intermittent problems.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
DVR won't turn on. TV screen is black
This can be a variety of different things, ensure television is powered on, what color light do you see on the front of your DISH Network 311 receiver? The green light is the one you should be seeing if the receiver is in fact powered on. If the light is not on even after pressing the power button on both the remote & the receiver, then I would recommend checking the source from which the receiver is plugged in, is it plugged directly into a electrical outlet on your wall, or is it plugged into a power strip? If wall outlet, perhaps try a different outlet and see if that makes a difference, if it's plugged into a power strip or surge protector unplug from wall and unplug receiver from strip for 30 seconds and reconnect checking to see if issue has been resolved. While checking these things, I would also recommend double checking to ensure nothing may have become disconnected and that all cables are connected from the back of your receiver to the back of your tv and to the wall and they are hand tight. I hope this helps, if the issue is still not resolved please feel free to contact me directly or you can call our technical support team for further assistance @ 1-800-333-3474. My direct e-mail is Kirstie.Filosa@dishnetwork.com.
-Kirstie DISH Network
May 14, 2010 | DISH Network 311 DTV Receiver
Installing a DVR
You are not able to use the DVR unless you have Dish Network services. Cable operates at a different frequency than Dish Networks Dish Pro Plus Receivers.
Sep 07, 2008 | DISH Network DVR-625 DTV Receiver /...
Wavy lines and jogging TV picture
it could be any of the things you listed, the coaxial output on the dvr, where it says channels 3-4 out, the cable , or the coaxial input port on your tv. the dvd player is probably hooked up with rca cables (red white and yellow) so the reason you dont have the issue with it is because its on a different port, one solution would be to hook your receiver up to the tv using this kind of cable, this would also get you stereo sound, you would then watch dish network programming on a video input channel,
if you want to narrow the problem down, i would suggest hooking a vcr up with the cable thats connected to 3-4 out, play a tape and see if the issue continues, if not the issue is with the dvr, if so try a different coax cable, if this resolves the issue, the issue was the cable, if not unfortunately the issue is your tv
Feb 20, 2008 | DISH Network DVR-625 DTV Receiver /...
Televison & Video Logo
104 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
