Machine stops at spin point in cycle. Same at each program
Error message " E"
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pump
Posted on Apr 12, 2015
I have a nec nw-691, when you put it on spin cycle it brings error message --lid open??? plz help
Yuo might try making sure it is still level but I'd just try using a lower spin speed. How have to use "gentle spin" when I wash towels or my washing machine has errors and stops. If still too damp just use a gentle spin only cycle once more to finish the job.
Apr 16, 2015 | Washing Machines
Machine gets to spin cycle, stops, and displays Error code 20.
Program does not move on as there is data error on the spin cycle due to wrong commands from the water level sensor/ program drive.
You must see if by choosing another program the fault changes, if so the drain valve or pump is faulty.
Check for dirt in the inlet, outlet valves, clean and set.Check the water level sensor.
This must clear the issue.
Aug 22, 2010 | Frigidaire GLTF2940ES Front Load Washer
Machine will run through entire cycle and will not spin. It quits at the spin cycle. I checked the Black boot at the bottom. Removed and cleared out coins. Checked pump- it was turning freely. Reinstalled...
I had a similar problem and found out the "latch" on the washer door broke off. The machine won't run in spin cycle if the door is"open", but it would run through the wash cycle.
Feb 05, 2010 | Frigidaire Washing Machines
Control panel reads E61 at wash cycle and E66 and drain and spin
Can you tell me what make this machine is? As it sounds like a heater problem??
Dec 28, 2008 | Washing Machines
I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Jul 29, 2008 | Washing Machines
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
