Question about Yard Machines Garden
Thanks for all your help the next time i have a problem i will b sure to stop at this site 250.00 later its fixed
Next time just say change everything 4 thumbs up
I have a 2004 Stratus that has an intermittent issue while accelerating. The check engine light comes on and the car starts to stutter. If I turn off the engine and turn it back on the engine light...
With what you changed and the fact that it is a 2004, have you had a tune up in awhile? Little things like a clogged fuel filter or plugged air filter cause this too. Make sure you have no vaccum leaks on your hoses. Visually check the coil wires and make sure they are not damaged. I have seen many problems with fuel pressure to the engine on the 04, mostly hesitation from leaking injectors. That is everything I would check. If you have any more questions, feel free to contact myself or any of our associates. We are here to help you. Thanks for using FixYa. Best wishes.
Feb 11, 2011 | 2004 Dodge Stratus
Just purchased a 2002 Nissan Sentra and 3-5 days later the car began shutting off when stopped on several occasions and starting back up. Lastly the car shut off while in park and would not start up again...
Next time it does it. try hitting the fuel tank. a couple times if necessary. if it starts back then your fuel pump is dieing. some times when the pump heats up they will stop working, only to come on latter. let me know
Nov 18, 2010 | 2002 Nissan Sentra
I have a 97 ford expedition 4.6L im having some trouble with. It started having some hesitation and sputtering in the acceleration and some backfiring when driving. First code said too rich or too lean in...
this may or may not help.
i have a 98 F150 with a 4.6 that i had an independent garage change the plugs and coil packs after i had the same problems you did. i had to take it back to him several times after and it never ran correctly, out of frustration i called the dealer where i bought the truck and took it to them. this was a small dealer about 200 miles from where i live, but my family is there. no large dealer ****, just leave the truck with us. one week later i got it back with everything fixed and it has run flawlessly since 2005. i was told that the problem was (1) the 1st guy didnt know what he was doing. (2) aftermarket parts didnt work. sounds like a load,but...
Apr 25, 2010 | Ford Expedition Cars & Trucks
My 2002 Taurus runs fine until I stop at a stop sign or stop light. It then dies but starts right back up and goes fine until the next time I stop. Please help.
sounds like a bad fuel pump...have this looked at by your mechanic...changed strainer and fuel filter at the same time..and if its been a while, the air filter too just to make sure that everything is breathing and working fine
Nov 18, 2009 | 2002 Ford Taurus
I have a P5LD2 motherboard and everything was going well, until it start to do horizontals lines on the monitor. I tried to stop the computer by the power switch, but it did not stop. I had to stop the...
If you are using an AGP Graphics Card, try a PCI VGA card. Maybe you have a faulty AGP adapter.
Assuming of course you know for sure that the Monitor and VGA cable are good.
Mar 06, 2009 | ASUS P5LD2 Motherboard
Backup
My Dear Dolly,
Do you know how time consuming this task is?
Well, as it is, I haven’t got anything exiting to right now, so what the heck.
Log in to your Domain Controller as administrator.
Click Start -> Run and type ntbackup
Click the Advanced Mode link
Click Backup Wizard
Click Next
Make sure Back up everything on this computer is selected and click Next
You can backup to a file, you place it wherever you want, just make sure you name it Friday and click Next.
Click Advanced.
Make sure Normal is selected as type of backup and click Next.
Check the box Verify data after backup and click Next (You will most likely have errors when the backup is completed and verified. This is because System State data is changed all the time. If there are too many errors, there might be problems with the file you are using to back up data.)
Click Replace the existing backups and click Next.
Click Later and in the Job Name box type Friday Nights, click Set Schedule.
In Schedule Task select Weekly and as Start time 08:00 PM (or whenever you want the backup to be scheduled). Make sure it’s set to run every 1 week and on Fridays. Click OK.
You will be prompted to run the task as a user. Use a user with privileges to backup data.
Click Next
Click Finish.
Dec 14, 2008 | Computers & Internet
Restoring a T2958
how about just leaving the name the way it is (the default) and not changing it.. (don't worry about doing it at that moment... you can always change the name of your computer later when everything is installed later.
also
leave your computer unplugged from the network (internet) and try again. (make sure not use any spaces or odd characters.. I don't think it would allow you to either but just in case)
Oct 17, 2008 | E-Machines eMachines Desktop PC
Stand by led blink 4 times
there is an internal short that needs to be eliminated about 250,00 to fix it
Jul 19, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Ticking sound
Hi,yes your engine does have a timing belt inside,shoul cost from $150,00 to$ 250,00 to replace ,be sure you take it to a recogniced shop, to get it check ,and to have the work done,.may be something else making that .(.noise.) good luck......
Jul 08, 2008 | 2004 Chevrolet Cavalier
Garden Logo
37 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
