What is 9,246 rounded to the nearest hundred - Office Equipment & Supplies
  • 3,287 Answers
Nearest 100 = 9,200
nearest 1000 = 9,000
Posted on Apr 08, 2015
5 Suggested Answers
  • 37 Answers
SOURCE: 4136 rounded off to the nearest hundred
4100
It would need to be 4150 or more to round up to 4200.
If your calculator has a function for rounding to the nearest integer, you will need to divide by 100 first, then round, then multiply by 100 again.
Posted on May 29, 2012
  • 7993 Answers
SOURCE: ACME Skateboards Inc., has paid
Doesn't any body do their homework anymore? How are they supposed to learn anything?
Draw your graphs by hand or on a graphing calculator.
Think about the intersection points. (What does that mean when two curves intersect?)
Use the equation for the demand to obtain D for a particular x.
You can also determine by how much one function exceeds another for a particular value of the x variable (the graph is rather clear).
I assume you can solve a quadratic equation.
Use these hints to solve the problem.
Here is a graph. I even restricted it to the first quadrant so as not to mislead you into giving meaningless answers.
Hope it helps.
Posted on Oct 04, 2009
SOURCE: i need to round 301,421,
Well that would be... 301,500,000 rounded UP, or 301,400,000 rounded down.
BUT the second answer, 301,400,000... is YOUR answer....
The nearest hundred thousand is 400,000... hence the answer, see?
Posted on Aug 19, 2010
rw93003
SOURCE: How can I change the setting to print total the
You need to set your decimal selection to full-floating if you expect any numbers to be more than 4 decimal places.
Each time you press the DEC key it changes the decimal selection. From F to 0, 2, 3, 4 and A in that order. F is "full floating" but appears as a blank on the screen. A is the "add-mode" for currency transactions. The "A" does show on the screen if this is your selection.
As soon as the letter for the number of decimal places you want ("F" is blank just before 0 decimals) appears on the screen you are "ready to go." Problem is, the decimal indicator numbers and letters are so tiny and screen is so difficult to read that under many lighting conditions your selections might be all but invisible. They are in the upper left side of the screen just to the right of the equally difficult to see multiplication and division rounding indicator "5/4." PS If the 5/4 does not appear on your screen then you have set the round-off function to not available.
Posted on Apr 01, 2011
What is 8,795 to the nearest hundred
When rounding, we always look at the number one to the right of the one we are rounding to. In this example, we are rounding to the nearest hundred, so we look at the number in the 10s column. In this case, it is 9. If the number in this column is 5 or above, we round the number in the hundred column up by one, and set the 1s and 10s columns to zero. You should get 8,800. If the number in the 10s column was 4 or below, we would leave the hundreds column the same as it was, and set the 1s and 10s columns to zero.
Good luck.
Paul
Mar 18, 2015 | Office Equipment & Supplies
What is 82,596 rounded to the hundreds, tens, thousands, and ten thousands.
Rounded to the nearest hundred: 82,600
nearest ten: 82,600
nearest thousand: 83,000
nearest ten thousand: 80,000
Sep 17, 2014 | Office Equipment & Supplies
How do you round 5,403.264 to the nearest hundred
Assuming you do mean to the nearest hundred, answer the question 'is this number closer to 5400 or 5500?' It is closer to 5400 (The first digit to the left of the decimal point is 'ones', the second place is 'tens', the third place is 'hundreds', so you look at the third digit to the left to round to the nearest hundred)
If, in fact, you meant hundredth, answer the question 'is it closer to 5403.26 or 5403.27?' It is closer to 5403.26 (The first digit to the right of the decimal point is 'tenths', the second digit is 'hundredths', so you look at the second digit to the right to round to the nearest hundredth)
Sep 17, 2014 | The Learning Company Achieve! Math &...
I neeed to round 740,692 to the place value
Round to which place value?
To the nearest million: 1,000,000
To the nearest hundred thousand: 700,000
To the nearest ten thousand: 740,000
To the nearest thousand: 741,000
To the nearest hundred: 740,700
To the nearest ten: 740,690
Sep 02, 2014 | Office Equipment & Supplies
53017 round to the nearest hundreds
The same way you would do it if the digit is something other than zero.
53017 rounded to the nearest hundreds is 53000.
Feb 14, 2014 | Office Equipment & Supplies
Round off to the nearest hundred 2x12x0.23
2x12x0.23 is 5.52. 5.52 rounded to the nearest hundred is 0 (zero).
If you want the result rounded to the nearest hundredth, it's 5.52.
Feb 04, 2014 | Office Equipment & Supplies
Alice said that 3,642 rounds to 3,600. Ned said it rounds to 4,000. Who is correct
They both are. 3,642 rounded to the nearest hundred is 3,600. 3,642 rounded to the nearest thousand is 4,000. Rounded to the nearest ten, it's 3,640.
Sep 19, 2013 | Dainese Alice Lady Textile Jacket Highrise
How to round off 41 to the highest value
What do you want to round it to? To the nearest unit, 41 is 41. To the nearest ten, 41 is 40, to the next highest ten, 50. To the nearest hundred, 41 is 0, to the next highest hundred, 100.
Jan 10, 2013 | Office Equipment & Supplies
I need to round 301,421, 900 to the nearest hundred thousand can you help me?
Aug 19, 2010 | Casio MS-80TE Calculator
55 people viewed this question
jasbo
jasbo
