HP Photosmart 375 InkJet Printer
Problem for HP Photosmart 375 InkJet Printer
Hp photosmart 375
By peezy on Nov 14, 2007
When i try to turn on my printer it begins the loading screen, than after a couple minutes it goes black than to an orangish screen with the power symbol and a code 07a74dd6. The green light in the front flashes and it starts all over. Any suggestions?
Same Problem
Jul 28, 2008
-   I keep getting an error saying printer cartridge stuck, and to fix and press ok but it's not stuck and won't work? -   Guest
Jul 07, 2008
-   I have same issue, but I don't have to original power supply, do you happen to know what the ratings of the correct one is?-   dewynsd
Jan 08, 2008
-   It happens with my equipment.-   Guest
Dec 29, 2007
-   07A74DD6 error appears on start up. then screen goes black and starts again with same numbers.-   dlj424
Nov 28, 2007
-   I kept on getting the error message 07564DD6 from my HP Photosmart A516 and it would continuously reset itself.
I had a similar problem with my HP Photosmart 385 printer the only difference is the error code is 07A74DD6. It is funny how little help I have got from HP. Luckily the solution is simple. You need to use the power cord that came with the printer. I didn't even realize I was using the wrong one, especially since I have several products that use one. Thanks a lot HP for nothing.
-   ambermiller
Best Solution
posted on Nov 23, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You are using the wrong plug
Solution #2
posted on Jan 25, 2009
Very Helpful)
l8ton65
Rank: Apprentice
Rating: 100%, 1 votes
As the previous message stated, I had the same problem and it was resolved by making sure that I used the original power cable. I couldn't find it at first and tried with three others all with the same error. Finally it was resolved by using the original.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jul 25, 2008
Not Rated)
larryritatee
Rank: Apprentice
Rating: 0%, 0 votes
HP Potosmart 375 printer error [printer cartridge is stuck clear and press ok---Can't seem to find problem any suggestion?
Was this helpful?
Yes
No
Popular Solutions for HP Photosmart 375 InkJet
Questions and Unsolved Problems for HP Photosmart 375 InkJet
Do you recommend HP Photosmart 375 InkJet Printer?
Answer
Answer
'Card access denied' displays when inserting
Answer
Photosmart 375 is not feeding paper properly. It either doesn't feed it all or begins and then jams.... (More)
Answer
The pinter has 2 cartridges - one regular black in and one for photos. The printer is only drawing... (More)
Answer
My HP Photosmart A516 will not turn on. When I plug it in all I get is a bunch of colored lines in... (More)
Answer
How do you print pictures via bluetooth?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Photosmart 375 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
