Question about Tracrac 2003 Chevy Silverado - Standard bed approx. 6 1/2 ft. - T-Rac Truck Bed Rack
Service engine Soon light has come on in my 2003 silverdo obd2 code comes up p0327
Obd2 code comes up p0327
Clearing check engine code, service engine soon codes on 2003 buick regal
Are you asking how to clear the check engine light?
Buy a cheap code reader ( $20 ) plug it in the OBD2 port which has to be no more than 3 feet from the steering column and clear the code(s).
If the check engine light comes right back on after you have cleared the code(s),read the code(s) and correct the problem(s).
Mar 29, 2018 | Buick Regal Cars & Trucks
Showing p0741 and the service engine soon light is on
P0741 Torque Converter Clutch Circuit Performance or Stuck Off, take a cheap OBD2 code scanner to erase the code, if the light come again, you need to take it to repair.
Mar 07, 2013 | Cars & Trucks
What are possible causes for the engine light to come on?
Hello
When the service engine soon light a yellow light (Also called the check engine light or engine management light) is turned on this is to alert you to the fact that Powertrain Control Module (computer) has detected a failure somewhere in the systems it controls you may not feel any difference in the way the engine runs, this can be the transmission or the engine or emission system, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Jan 29, 2013 | 2003 Mazda Tribute
Service engine soon light comes on once in awhile, when this happens at the stop lights it feels like it wants to take off and has a slight vibration. I had it hooked up to the computer and did not show...
Hello
When the service engine soon light (Also called the check engine light or engine management light) is turned on this is to alert you to the fact that Powertrain Control Module (computer) has detected a failure somewhere in the systems it controls you may not feel any difference in the way the engine runs, this can be the transmission or the engine or emission system, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Sep 10, 2012 | 2003 Cadillac Deville
How to reset service engine soon light
The engine light is on whenever there is an issue with the vehicle. To reset the light you would have to fix the problem and then clear the code with a scanner otherwise the light will come back Just resetting doesn't fix it.
Jul 08, 2012 | 2003 GMC Envoy
What is the service engine soon botton
Hello
When the service engine soon light (Also called the check engine light) is turned on this is to alert you to the fact that powertrain control module (computer) has detected a failure somewhere in the systems it controls, this can be the transmission or the engine or emission system, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Jun 28, 2012 | 2006 Nissan Pathfinder
2002 nissan altima has low speed when acelerating
Hello
When the service engine soon light (Also called the check engine light) is turned on this is to alert you to the fact that powertrain control module (computer) has detected a failure somewhere in the systems it controls, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Jun 22, 2012 | Nissan Altima Cars & Trucks
ENGINE SERVICE LIGHT TURN ON GRAND VITARA 2003
The information below was complied by me, it explains what causes the check engine light to come on and the process of finding the cause.
When the Check Engine light (or Service Engine Soon) is turned on, the systems computer control unit (called the PCM) has sensed a fault in the electronic controls of the engine and/or the emission system. When this happens you will seldom feel the car engine run any different. There are about 200 possible faults that turn the Check Engine light on, to know what has developed a problem you must have the system tested, this is called an OBD2 fault code test, Kragen and Autozone parts stores (USA only) do this testing for free.
Jun 22, 2011 | 2003 Suzuki Grand Vitara
When the engine service light turns on what should i do
The check engine light/service engine soon (yellow light) comes only when the computer control unit (called the PCM) senses a fault in the electronic controls of the engine and/or the emission system u will seldom feel the car engine run any different, there are about 200 possible faults that turn the light on, to know what has developed a problem you must have the system tested, this is called an OBD2 fault code test, Kragen and Autozone parts stores do this testing for free.
Sep 27, 2010 | 2003 Oldsmobile Alero
Tracrac 2003 Chevy Silverado - Standard bed approx. 6 1/2 ft. - T-Rac Truck Bed Rack Logo
625 people viewed this question
Top Tracrac Boating Experts
Lawrence Oravetz
Mike
Are you a Tracrac Boating Expert? Answer questions, earn points and help others
