No Video with sound and thin vertical lines across screen
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Posted on Apr 09, 2015
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Screen is black with a thin horizontal line
Change the vertical IC and check the electrolitic capacitors near them
Aug 28, 2009 | Televison & Video
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Thin white line across center of screen Fisher PC-32S90
yes there's a lose connection of your tv. It needs to re solder.if you know how to solder .,solder the vertical section specially the vertical I but be careful of short circuite coz it may damage your tv set.
Nov 16, 2008 | Fisher PC-32S90 TV
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
