Question about Miscellaneous
I've pulled and held the switch and it won't start. There is power and gas getting to it but it just won't start. What should I do to get this going?
  • 5,323 Answers
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Posted on Apr 20, 2015
2 Suggested Answers
  • 638 Answers
SOURCE: A 2001 ford escort zx2
i would have someone check the computer out.
Posted on May 11, 2011
2001 nisson pulsar. engine stalls (randomly) more often on hot days then wait 5 mins and it starts.
Try getting a new gas cap. If the vent is plugged it creates a vacuum and won’t pump gas. Wait 5 minutes and the vacuum is gone and it will start. Hot days will expand the gas and be more of a problem.
Jan 19, 2018 | Cars & Trucks
Bike won't start. No voltage to fuel pump fuse on 2008 Ultra Classic Electra Glide. Have power on all other fuses. Any suggestions?
Get some good electrical cleaner spray displays that connection scrubber with alcohol, make sure the fuses good and try again pulled a plug-in out, even though you charge the battery make sure the battery has 12.67 V of starting juice. How was your battery may be needed. New battery
Sep 29, 2012 | 2008 Harley Davidson FLHTCU Ultra Classic...
Ok so I bought a 94 Chrysler concorde... the guy told me you have to turn the key multiple times before it starts...the starter doesn't kick in until basically it wants to...lol he said the ignition...
You may be right. Sometimes a starter test doesn't reveal everything. But before you pull the starter, do this quick test. It should confirm if problem is the starter or the ignition switch. When the car won't crank over, pull the small wire off the starter solenoid (on the starter), and check if it has power when key is held in crank position. You need a helper to hold the key in crank. If the wire has power (use a testlight or meter to check for power), and the starter won't crank, pull the starter off for testing or replacement. But if there is no power on the wire when key is held in crank, then it confirms that power is not being transmitted from the switch to the starter. Not to say for sure it is the switch, could also be another part in the path from switch to solenoid (like the neutral safety switch). But more common for the ignition switch to go out first. Either replace the switch or continue testing your start circuit. Post back with results or for further help. Good luck.
Jun 14, 2012 | Cars & Trucks
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
Model # 21a4228129 will i pull to get it to start it won;t. Am I forgetting to do something. I place the choke level, turn the gas lever, have it in nutural. Help!
If you have a safety bar, this bar must be squeezed or held down while starting. Does the engine seem like it tries to start???
Jan 08, 2010 | Mtd Products Yard Machines 158CC Tiller
Miscellaneous Logo
14 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
