Question about Husqvarna Garden
I have a Husqvarna 375k cut off saw. It has spark, rebuilt carb, good compression, I even sprayed a little starter fluid in the cylinder and it won't even try to fire. Definitely has spark
    Master:
  • 301 Answers
Try taken the spark plug out , using the starter cord slow pull on the string. Looking inside where the spark plug was, does the cylinder move up and down?
If it does you might have a bad ring around the cylinder.
One last thought, make sure that the spark plug is clean and re-gap correctly.
Posted on Apr 08, 2015
5 Suggested Answers
  • 83 Answers
SOURCE: 46 cc Sears/Poulan chainsaw will not start
Four things I can think of:
1) There is a short in your spark plug wire. When you bend it to connect the plug in the machine it allows the exposed cable to contact the engine block. Examine the wire all the way to the coil.
2) Flywheel key is sheared ( you obviously know how to take off the flywheel since you checked the seals).
3) Flywheel air gap is not set correctly. Loosen the coil. Put the cover of a notebook or the cardboard piece of a cigarette pack between the magnetic portion of the flywheel and the coil. Tighten the coil down. This will get you the proper gap.
4) Your cylinder/piston or rings are scrubbed out. Even though it passed a compression test, on rare occasions it will loose compression only when it fires. So do the following:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
First if you can get a inline spark tester so you can see if your getting spark with the plug installed.
Posted on Mar 31, 2009
  • 403 Answers
SOURCE: After long storage, cleaned carb,
you say you cleaned the carb, most importantly, did you clean the jet in the carb. if not there your problem. The ethonal in gas will gum it up in a heartbeat if not run.
Posted on Mar 11, 2011
2strokeJim
  • 577 Answers
SOURCE: Stihl MS 290 won't fire even when primed directly into cylinder
crank seals are probably shot :-(
Posted on Nov 29, 2012
SOURCE: saw will not fire. has
no spark at plug
Posted on Feb 01, 2013
Chainsaw won't start
Replace the condenser. You'll still get spark with a week or dead condenser, but no fire under compression.
Aug 06, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Saw won't start without starting fluid.
Sounds like you have a compression problem. Starting fluid will fire at a much lower compression than a gas/oil mix so that's why it will start with it. When the motor is running you get a little more compression because the piston is coming up so fast. You should check the condition of your cylinder wall and piston & ring. If they are damaged at all you loose compression which directly affects starting and running power.
Mar 28, 2012 | McCulloch Garden
My chainsaw starts and idols ok ,when I try to cut a log it bogs down and stalls off
Sounds like a carb problem. My 310 stihl did the same thing. Rebuilt the carb and now it will cut the gates of the hinges off of H**L
Sep 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Model 51 won't start. Was running fine and has never had a problem starting (owned since new, 14+ years). Chain slipped off. Fixed and then saw wouldn't start. Good bright spark &...
If you have a good spark, and there is fuel at the plug, the only things to stop it fireing up are a sheared flywheel key knocking the timeing out, or the engine has low compression due to wear or damaged piston and ring.
Sep 07, 2011 | Garden
I changed fuel filter ,fuel line to carberator ,rebuilt carberator and adjusted properly put new mixed fuel and coil is new and gets good spark motor has compression motor fires and stops runinng riteaway ...
Are you sure you pump in the unit properly? Some carbs have the gasket against the carb body and some have the pump next to the body. Also check the needle valve for proper operation,and dirt.
Jan 20, 2011 | Husqvarna Partner K1250 Cutoff Saw Air...
Husqvarna 350 '' has spark but won't start????????
Did you spray the starting fluid into the plug hole or the carburetor opening. Check the muffler for plugging as well as the air cleaner. When you have the muffler off of the engine, inspect the piston skirt and cylinder wall for any serious scuffing caused by either dirt in the engine or loss of lubrication. This is usually accompanied by loss of compression in the crankcase and upper cylinder. It's possible that the flywheel key has sheared causing the spark to occur at the wrong time. Hope some of this helps!
Apr 11, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna chain saw Model 141 running at high rpm's
You may wnat to inspect the intake manifold/boot that mounts inbetween the cylinder and the carb. Also, the impulse tube that comes from the bottom of the cylinder to the carb manifold or carb itself. Sounds like you are running a lean condition. You need to locate the source very quickly, or continued operation will permantly damage the saw. I have listed a few other things to check.
Please let me know what you find. rwvanlue
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 13, 2009 | Husqvarna Garden
Runs great for 30 sec. to 1 min. then dies slowly
Is it your chain saw Husqvarna 40?
Try carb adjustments H-3/4 turn ,L-2 turns and T a little higher
I presume that compression and ignition sistem is adequate for the engine to run.Good luck
mihai
Apr 04, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What coul be keeping my 1986 honda civic from starting? The plugs all spark, the fuel pump gives gas to the carb, Ive changed all plugs cap and rotor and have tried spraying starter fluid directly into...
It cranks really good sputters a little and makes some loud pops but it will not turn over? FYI:Cranking and turning over are the same thing. When was the last time it ran. The gas could be bad. Did you get new plug wires as well. Try testing the distributor, remove a spark plug, plug it back into the wire, and touch the threads to ground and crank the engine. It should spark. Keep your fingers away, that's high voltage. Remove all spark plugs, spray some starting fluid in each cylinder, then crank the engine with the plugs out. This will clean any debris from the cylinders. Engines need backpressure to run properly, a major exhaust leak hence the popping, could cause it to not run. If you can get it started try to keep it going, full throttle, keep in the starting fluid, it could just need to get warm. I used to have one of them and they don't like it when they're cold.
Mar 23, 2009 | 1986 Honda Civic
Garden Logo
134 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
