Beko WMA520s door won't open at end of wash!
At the end of the wash, the door won't open. I have tried the solutions posted to similar issues online such as holding the start button for 3 seconds and having it turned to 90 degree. I have one bed spread in there which is quite heavy and full, but the whole wash has completed as per normal (and have washed it before!) - except now can't open the door. Nothing is trapped in the door. Please help. Thank you for your assistance. It's greatly appreciated
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Turn off and hold door in for 2 mins
Posted on Apr 12, 2015
SOURCE: beko wma520s start button flashing will
problem sorted by removing filter drain plug very slowly to empty machine of water and any blocked residue. check drain hose is not kinked. reset machine and rinse through on empty ie no washing.
Posted on Apr 03, 2008
  • 6 Answers
SOURCE: beko WMA 1715s - won't respond
door lock switch could be your problem..
Posted on Aug 30, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Duet 9200 Washer door lock issue
no thiis is normal operation, it is considered a child safety feature. in case a sleeping child should happen to be in machine, the short 2 sec blast of cold water will wake them and give them a chance to exit before the machine starts washing.. all whirlpool frontloaders do this, thats how it waas explained to us at factory training.
Posted on Dec 04, 2008
SOURCE: My beko washing machine wont do anything at all!
Hi,have you ever solved the problem? Mine is doing exactly the same thing.
Posted on Aug 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: Simpson Front Loader won't start - Clicking Noise
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
The door on my Hotpoint Washing Machine WT741 won't open even though the programme has ended. We've tried running the programme again and pumping out but still the door won't open.
The door latch may have broken. You can sometimes open the door from the inside. You will know the door latch is broken if the door handle is floppy. If the door handle is not floppy - then the issue is probably with the door interlock. This is the electronic part that prevents the door from being opened during and after the wash has finished.
Either way - you'll need to get the door open.
To do this, unplug the washing machine from the mains and then move it out from where it is. Tip the washing machine to a 45 degree angle. Don't tip it over 45 degrees as you may break internal parts.
You need two people to do this - one person hold the machine at 45 degrees angle, whilst the other person puts their hand up into the machine - you should be able to feel the door catch mechanism and depending on the model, open the door that way. Sometimes the manufacturer has helpfully put a manual release inside - and sometimes they don't.
If you aren't able to open the door using that method. Get a length of strong string and poke the middle section of the string into the gap between the washer door and the machine body - to the right of the door handle. Use a flat headed screw drive to push the string into the gap, all the way around the door, so that you end up with the two ends of the string on the left hand side of the door. Now have someone put the ends of the string whilst the other person pulls the door handle. If the string is pushed in far enough it will release the door latch and the door will open. It takes a bit of persistence to get it right.
Once you have the door opened you can usually replace either the interlock mechanism or the door latch itself. Parts are easily available online from sites like espares and yourspares.
Mar 29, 2013 | Washing Machines
Beko washer is leaking water from underneath
This video will show you in detail how to replace the door seal gasket and fit the new one properly to a Beko washer that is leaking water from underneath washing machine How to Replace Beko washing Machine Door Seal
Jan 24, 2013 | Washing Machines
Hi - just fitted my beko washing machine after moving .Disaster!! When the water began to fill it come straight out of the bottom through a disconnected 10mm black hose about 300mm long .One end was...
a 10mm pipe is not the main drain pipe. The 10mm black pipe is for manual emptying and should have a blue stopper to plug the end, pull off the front bottom panel, and there should be a small opening, inside this opening is the manual drain pipe. Check to see that the blue stopper is still connected. If not, then you can buy these for less than a fiver online.
Oct 06, 2012 | Beko WME7247W Washing Machine
How to reset Beko wmb 91242 LC? Machine won't do
My washing machine beko WME7247W won't do anything it said C on it won't start change tem do anything can you help me
Apr 08, 2012 | Washing Machines
Door locked
sounds like your interlock has failed you can buy from any appliance spares outlet or online regards jason
Jun 08, 2008 | Indesit W 123 Front Load Washer
Beko wma520s start button flashing will
Mar 31, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
