Question about Maytag Washing Machines
Maytag 4000 series MHWE450WW02 has power but when start button pushed shuts off
  • Maytag Master
  • 5,323 Answers
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Posted on Apr 20, 2015
blueextc3221
  • 15935 Answers
SOURCE: shuts down when start button is pushed
There is likely a short on the ECU and it must be replaced. Further testing should be conducted by a professional in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 10, 2010
  • 6277 Answers
SOURCE: looking for service manual on
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Apr 18, 2011
SOURCE: I push the power button
Any luck? the certified Maytag repair company looked at mine and quoted $445. for the repair. it is 15 months old so of course the warranty is obsolete. The solution is a new CCU panel and Temperature sensor. Good luck.
Posted on Sep 06, 2011
  • 313 Answers
SOURCE: i have a mct maytag 4000 series
Does it make any problem besides the code ?
Posted on Jul 25, 2012
perkins48
  • 14363 Answers
SOURCE: How do I fix a broken power button on my Maytag 4000 series washer?
Tray tighten the silver ring ,turn clock wise,unplug and plug back in,if no luck then you will have to remove cover to remove switch to replace and take switch to appliance dealer,they will have to order part.
Posted on Oct 23, 2012
I have a maytag dryer mgd9206aww i push the start button and it has power but it wont spin and shuts down seconds later
Could be electrical motor could be bad thermal limiter on motor could be shutting it off
Feb 18, 2015 | Maytag Dryers
MAYTAG 5000 SERIES WITH STEAM WASHER WONT START
the lid isnt being detected as closed
the switches have a fault in them
Dec 05, 2014 | Maytag Washing Machines
Maytag 4000 series washer mhwe450wr01 just beeps once when I press the power button
Maytag's address used to be #1 Dependability Blvd, Newton Iowa. Not any more. Now they're made elsewhere by a company that bought the name and not the quality.
Oct 14, 2014 | Washing Machines
Error Code F24 Maytag 4000 Series Front Load Washer
This video will show you how to open your Maytag 4000 series washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2013 | Washing Machines
Oct 23, 2012 | Washing Machines
Maytag dryer won't keep running
poss the starter relay.
Mar 16, 2008 | Dryers
Washing Machines Logo
131 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
