Question about Pool & Spa
I have a Coleman spa that works fine for about 15 minutes or so and then. The one pump stops and starts to surge on and off .the switch won't let me turn it off or on I've burned up one pump because
  • 1,631 Answers
Do you have an auxiliary remote control panel?
Is it plugged into the cable of the main control topside panel?
If you do you have a remote panel, and it is not plugged into its own receptacle on the circuitboard, but onto the cable of the main top side panel, that remote panel may have a short. As it would override the ability for proper operation at the main panel. Disconnect that remote panel, it will not lessen the ability of spa operation, other than the convenience factor of having a remote panel, it should repair your problem.
Posted on Apr 14, 2015
SOURCE: High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
Posted on Apr 19, 2009
TheSpaDoctor
  • 10 Answers
SOURCE: maxi flow spa booster pump, buzzing...then cuts out
hi the capacitor needs replacing in the pump connection box, this needs to be exactly the same uF value as the one you are taking out.
Posted on Jul 08, 2009
  • 8 Answers
SOURCE: Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
Posted on May 09, 2010
  • 8404 Answers
SOURCE: I have an XP2 in my 6 year old above ground spa.
You have a gage on your filter? Anywhere on your system? I would suspect yout system should run at about 18 to 28 lbs PSIG when clean and go up about 10 lbs PSIG when it needs to be back washed.
Posted on Aug 21, 2010
aquaman987
  • 927 Answers
SOURCE: I have a Hayward Power-Flo
I have a 3/4 hp hayward pumping thru solar panels, too. 1-1/2 discharge thru 50 ft of 2inch pipe, up 12 ft then thru (4) 4x12 panels. Mine is on 115 volts ac.
You have plenty of pump and when you run a pump with low flow, amperage is low. You are not tripping your breakers, it sounds like the pump is overheating. Is it hot to the touch when it shuts down?
Do you have an ammeter so you could check your amps?
What size wire is running the 60 ft to the pump?
I don't have any other ideas to share.
Gary
Posted on Sep 06, 2011
I just bought a used older garden leisure spa, it won;t turn off. The manual says push button once for low pump, twice for high pump and a third time for off. I only get low and high pump speeds.
This can be normal depending in the settings. It may continue to run for upto 15 minutes, its just looking to satisfy it's heat or filter cycle.
Dec 14, 2016 | Pool & Spa
Heat Pump comes on, fans slow down, switches off?
Sounds like a bad temp sensor or switch. Like in cars my guess is that the switch is failing to work causing the fans to stop despite the pump getting hot.
Jun 23, 2014 | Aquacal ICEBRKR HEAT/COOL 110K TITANIUM...
Dreammaker x-400 clicking sound and pump surge
This might be a problem with the topside control. When the spa is clicking, try unplugging the topside control and see whether or not the problem stops. If the jet button is stuck on the topside, the pump will turn on-off-on-off-on-off until the topside is unplugged.
If unplugging the topside worked, replace it.
Apr 11, 2017 | Pool & Spa
My pump works on low speed but not high speed
these are a bear to work on.. there are start switches inside of the motor, and will break if you even look at them wrong.(fragile) you can try compressed air to blow out the trash that might be in the switch..or unhook power cord of the motor from the motherboard and remove the pump and motor from the spa , bring it to your local pool pump moor repair guy with free testing have it tested. if removing wires from motor YOU MUST REINSTALL THEM EXACTLY AS THEY CAME OFF ! OR YOU WILL BURN UP THE expensive 2 speed motor .. jay Florida
Dec 20, 2011 | Pool & Spa
The flow of water starts at a high rate then within 15 minutes it slows to nothing
CHECK TO SEE IF THE IMPELLER IF GOT TRASH IN IT..IS THE STRAINER BASKET CRACKED ? IF SO REPLACE IT ...AND HEAR IS HOW THIS PUMP COMES APART
Aug 03, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
I have a proline pool pump model # SD-15-1N11CC and it worked fine until I back washed my pool and now it stopped working. It makes a humming noise and nothing else.
C. MOTOR HUMS, BUT DOES NOT START—
Check for:
1. Centrifugal switch stuck in open position.or if capacitator start could be bad capacitator. Possible loose connection.
2. Binding of motor shaft. (something stuck in impeller) Does motor turn free. IF not check for jamed impeller. If it she sp2605x7 you can view a manual here:
http://www.haywardnet.com/products/Manuals/pdfs/manual113.pdf
Aug 17, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Coleman mach 8333 kicks breaker
I changed out the startup and run capacitors. A/C runs fine now
Jul 22, 2008 | Coleman Mach 15 Air Conditioner
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
