Question about Brother HL 2140 Laser Printer
Maintenance_ink_pr This is connected to my laptop and I have always used this for printing and now it tells me it's offline and the above Maintenance_ink_pr message appears, Datatype RAW, Processor winprint
3 Suggested Answers
SOURCE: "SET CARTRIDGES OFFLINE"
Make sure the ink is properlly installed.
Posted on Aug 24, 2007
MerlinTech
  • 197 Answers
SOURCE: Unable to Print - See Chapter in users guid troubleshooting and routine maintenance
can it do a test page?
Posted on Jun 16, 2008
Maintenance ink pr
Can you please explain what is happening, are there any error messages or what happens when you try to print etc.. the more details the better. Thanks
May 31, 2013 | Brother MFC-9320CW Color Laser Printer -...
I can not get anything to print on my Epson NX420 using my IMAC. It says the printer is offline and I can't even print a test page. Can you help?
I'm assuming the printer worked previously from the iMac and now it does not. If you never had it connected, please add a comment to this effect, and include your OS version.
First, Open the Print Center (Printer Utility) and check the status of the printer. It may be listed as stopped. If so, delete any extra print jobs (additional attempts to print the page), then click the Start Jobs icon.
You can verify printer connectivity by clicking Add in the Printer List (if that is not visible, select Show Printer List from the View menu). Be sure to select either the USB or wireless network protocol connection. If the NX420 shows up, you have a good connection. In that case, click cancel and skip the next paragraph.
If you are printing via USB, check the cable (I sometimes forget to plug in my printer cable after downloading from my camera). If you are printing via your wireless network, check the status of the wireless connection from the printer.
Also, in the printer utility window, click the Supply Levels icon to verify that all of the ink cartridge levels are high enough to permit printing.
Are there any error messages on the printer display? A fault detection will take the printer offline.
Jun 22, 2011 | Epson Printer
Our hp color laserjet printer is not printing... all the ink cartridges are new and inserted correctly... we have no idea what's wrong
There can be a number of things that are wrong so bear with me as I list some suggestions or possible solutions.
Always, ensure that your cables are securely connected between the PC/Printer and your AC Power cord is securely plugged into the outlet as well as the back of the printer. Additionally, make sure that the printer isn't indicating an internal problem such as low toner, paper jam or some error code on it's display. If everything on the printer appears to be normal, proceed to the next paragraph, If there are any error codes or messages on your printers display, you'll need to look those up to clear those issues before proceeding.
Open your print queue in your computer, (Control Panel > Printers> HP Color Laser or name of your printer) verify that your printer is seen as the "Default" printer and that it isn't currently selected to work "Offline".
If it shows that it is the "Default" printer, and it is NOT selected to "work offline", then let's try the next step. If for some reason it isn't the "Default" printer, you can select it to be so. If for some reason it shows that it is "Offline" uncheck that selection.
Under your printer "Properties" (right click on your printer, bottom selection on the drop down menu) you will have a "Self Test" button. Click this button (only once), observe your printer and see if it prints a test page.
If your printer shows no error messages, all cables are secured (always double check), your printer doesn't show it is offline in the printers queue, it properly prints the test page then at this point it should be working correctly.
If the steps I have mentioned above don't work, please provide more detail as to the printer model, any changes that you have recently made (software installed, cartridges changed, etc.) and we will find you a solution.
Aug 31, 2010 | Computers & Internet
Printer offline
Several printers are connected to my Dell and sometimes without paying attention I forget which printer I'm using. On your print set up page scroll down until to your printer and select it. If you have only one printer, then select it as your default printer.
Jul 01, 2010 | Brother MFC 7840W Printer
I recieve a message when trying to use my pixma cannon ip 90 that reads the color cartrige is empty, so i replaced it. still gettin message and wont print.....please help dallas44432@yahoo
Go into control panel, and right click on your printer and select properties. Under maintenance you will find the reset to show the inks as new. Also if you open the top cover while connected to your computer and then try to print a window will pop up asking if you put in new ink, answer yes and tell it which ink is new and it will be reset.
Feb 01, 2010 | Office Equipment & Supplies
False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error message after replacing the black cartridge
You must replace both ink carts to get an alignment.
Dec 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Not printing
my printer doesnt work, what do i need to do so that i can use my printer again,pls kindly give me the information, it always said that go to the maintenance and routine maintenance chapter. i have no any idea on that device, pls!!! thanks!!!
Jul 03, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother HL 2140 Laser Printer Logo
146 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
