Question about Crafts & Hobbies
1) train will only go half way around track then will reverse on its own or just stop
2 Suggested Answers
SOURCE: lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
Posted on Dec 25, 2008
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
How do i set up electric tyco train set- model 899v hobby transformer?
There are 2 wires from the transformer to the power rail screws on the track. Hook up the wires and watch the direction the engine moves when you move the lever to forward. If the engine moves in reverse, either swap the wires or turn the engine around on the track.
Nov 01, 2014 | Crafts & Hobbies
My 1941 Lionel train stops getting enough power to run all the way around the track. Voltmeter says 15 volts around all track and transformer says 15 volts. How do I test engine?
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Dec 16, 2013 | Lionel Trains Classic Freight Train Set
Wiring 1122 switches for crossover
Question is unclear. But if you want both switches to throw at the same time all you need to do is connect the 3 terminals on one switch with the matching terminals on the other switch. Run a wire from left to left, center to center and right to right. If the switches do not switch into the same track just reverse the right and left wires on one of the switches.
Nov 27, 2013 | Lionel 40 Watt Transformer Train Set Track...
1988 Playskool Expres Train engine won't run. Light comes on but wheels won't turn. How can I repair it?
i recently restored a playskool express train that my son had, now for my grandson.
The on-off push switch is the yellow button in the smookestack also controlled by the yellow tab on the bottom (the on-off track can stop the train with the tab). If the light is on then perhaps the forward reverse switch (the yellow bar behind the cab needs to be pushed forward or backwards. In the middle might be off. I had to replace the motor, its a common sized DC motor 6V at 15000 RPM w/ 2mm shaft, for toys..
The bigger problem I had was that the battery cover was very finicky in how tight you closed it, and the rubber traction bands for the driving wheels were rotten. I replaced them with 1-5/16" ID x 1/8" O-rings. Still slips a little.
Dec 10, 2011 | Playskool Toys
When the train is heading around the track, it stops on the curve, and will only start again, when you turn it off and back on??? Does this on both ends when turning the corner? Can you halp??? Tha
Check to see if the train is lifting off the track on the curve and the roller is not making contact with the center rail. Run the engine alone slowly and try both forward and backward.
Nov 20, 2011 | Lionel Harry Potter Hogwarts Express...
I just bought a Bachmann - Spectrum® Village Street Car Christmas Train Set - On30, for my window display and for some reason it only flips into reverse at the end with the car barn, but not at...
Make sure that the last track before the bumper is marked to be at the end of the trck - it will be marked on the bottom of the track and there will not be electrical connectors at one end of the track.
Nov 25, 2010 | Bachmann On30 Christmas Village Street Car...
New Bright Model #183 - how do I make the train go? The light works when the engine switch is in forward and reverse, but the train doesn't move (wheels do not turn). The music plays from the coal are -...
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Nov 27, 2009 | New Bright 181 Toy Christmas Train
An electricalroblem with Holiday Express train
Mar 31, 2009 | New Bright 181 Toy Christmas Train
Lionel train won't reverse
Dec 17, 2008 | Lionel New Haven Freight Train Set
Crafts & Hobbies Logo
416 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
