Question about Danby DFF261BSLDB
Refrigerator won't cool below 18c.
Freezer unit works. The refrigerator, no longer makes "water" noises, and when it runs, sounds different than previously.
  • Henry Parker
    Henry Parker Apr 08, 2015
    How long would it be expected for the freezer to maintain freezing temps if the compressor were shot?
  • Captain Neal
    Captain Neal Apr 08, 2015
    A day, perhaps two at most if it was full of frozen food.
    Novelist:
  • 174 Answers
Makes no sense to me as this refrigerator only has one compressor/evaporator. The freezer should also cool the refrigerator section. Try defrosting the freezer - perhaps ice has somehow blocked any airflow to the refrigerator section.
Posted on Apr 08, 2015
  • Henry Parker
    It automatically defrosts. How long would the freezer hold freezing temps if the compressor were shot?
Dirty heat exchanger
the condenser (air intake) is blocked, most likely with dust, and the fan isn't passing enough air flow. either the fan is overworking and making noise or the compressor is overheating. if it can't cool down, the evaporator (cold coil) won't get cold enough to collect condensation. unplug the unit, take it outside, open the front, and hose the condenser down. if you can see light through it, it's ok. if not, spray some simple green degreaser on it and hose it down again after about 5 minutes. if you have a stiff bristled brush, use that, too.
May 14, 2012 | Haier Dehumidifiers
Dehumidifier seems to not be dehumidifying
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Jun 09, 2008 | DeLonghi Dehumidifiers
Tip
Dehumidifier Problems and Dehumidifier Troubleshooting
If you have a dehumidifier that is not working correctly you have many things that could be causing it not to work. Here I will give some of the common reasons why it could be giving you problems.
  1. The coils in the back are frosting up.
The dehumidifier works by drawing the room air over a very cold coil. The trick is to keep the coil as cold as possible to make it pull water out of the air by making it condensate on the cold coil. If this coil becomes too cold, then the water freezes on the coil. The freezing can happen if the air temperature in the room is too cool and does not keep the coil warm enough. Raising the humidifier up off of the floor onto a table can help. The air temperature is often a bit warm the higher up you get. Make sure that the filters are clean if your unit has one. Restricted air flow will make the problem worse. Providing more heat to the room will help also. Most units will not work in a room with temperatures below 68 degrees F.
  1. There is no air moving over the coils.
This can happen if the fan motor becomes stuck or burns out. If it becomes stuck you can sometimes get it running by working a lubricant into the bearings. WD-40 first, and then a good motor oil. If the motor burns out it will need to be replaced.
  1. The indicator light is on and the unit will not run.
This shows you that the bucket is full and needs to be dumped. If your unit is working correctly and the air is very damp you may only run a few hours before the bucket becomes full. This also can happen if the bucket is not seated in it’s spot correctly. There is a little switch that will not let the unit run if the bucket is not place exactly right.
  1. There is no water being produced.
This can happen if the air is very dry and no water can condensate from the air. Check the coils to see if they are cold to the touch, actually they should be very cold, like almost freezing. If not then the refrigeration system of the dehumidifier has gone bad. To repair that you will need a person certified to work on refrigerant systems with specialized equipment. In many cases the costs to repair the refrigeration systems will more than the cost to replace the whole unit.
This should give you a brief overview of the problems that you can have with a dehumidifier and some of the things that you can do to help get things working.
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
on Jan 13, 2010 | Dehumidifiers
LHD659EBL The fan runs as normal, compressor runs normal,but coil ices up.
The icing is generally caused but 4 basic things:
1. The air intake filter is very dirty or clogged and needs to be removed and cleaned.
2. There is not enough clear air space surrounding the unit. You need to maintain 12" to 18" around
the entire unit.
3. The cooling coils are dirty and need to be cleaned. This can be accomplished using a sponge
dipped in warm water mixed with a mild dish washing liquid, rinsed, wiped dry and the applying
a light coating of WD40.
4. The dehumidifier is being used in a basement, where the air temperature at floor level is colder
than at shoulder level. Dehumidifiers struggle to work at temps below 65 degrees F. Raising the
unit up off the floor, onto a sturdy table or counter top will generally solve the problem. It must be
sturdy enough to handle the weight of the unit, plus a full tank of water.
A less common problem is a small leak in the cooling coils. Which allows the refrigerant gas to escape and frost the coils.
Hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 16, 2011 | LG LHD659EBL Dehumidifier
Dehumid....ad70usso....runs all the time auto settings don't seem to working collects fine ..but won't turn off when air is dry thanks
There are 4 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. Also, keep in mind, basements stay moister longer than upper rooms.
1. The humidity extraction level is set to HIGH. Lower it to 32-35% and disable the auto mode.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Jul 14, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
The fan runs good. Cool air comes out the front of the unit but it doesn't condense any water. Someone told me I need to add refrigerant. Does that sound possible?
yes,its entirely possible cause after 2-3 yrs they lose some charge,make sure you read the compressor tag for correct refrigerant
Jul 01, 2011 | DeLonghi Dehumidifiers
Dehumidifier won't fill up with water and makes
If the machine's compressor runs when you switch it on, then turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you would need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options can potentially cost about the same.
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. If your dehumidifier is freezing up then that probably means the unit itself is actually working well. The temperature or humidity level in the room may be a bit low and you may have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit. Remember to also clean the air intake filter while you are at it.
If the ambient temperature in the room is a bit low, you can try adding some heat to the room if necessary. A dehumidifier will not work properly if the ambient air temperature is too low. Generally, the warmer and more humid the room is, the better they work.Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where the air is warmer.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
The rattling noise may just be the coils vibrating against each other. Sometimes you can gently bend the coils apart slightly so they don't rattle, just dont bend them too much or you might damage them.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 27, 2011 | Dehumidifiers
Makes a crackling sound while running
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 02, 2010 | Whirlpool 75-Pint Dehumidifier
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
Danby DFF261BSLDB Logo
131 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
