Can I use headphones on a Kindle?
If so, where can I get a lead?
    Novelist:
  • 174 Answers
Some Kindles have an earphone jack and some don't You can use earphones only if your Kindle has the earphone jack. It is the mini-jack like used in iPods and iPhones and many headphones (as opposed to ear buds) use a larger size jack.
Adapters are available. Try Radio Shack for adapters and lead cables. Keep in mind that most earphones require more power to operate than earbuds do and the Kindle may not be able to sufficiently power headphones to get any decent volume.
Posted on Apr 08, 2015
My kindle is not connected to the wifi how do i connect Thanks Marg
It's done in software. go through the menus, look at the options, and select wifi on or off at the appropriate place. (pressing the 'home' button might be a good place to start) I keep wifi permanently off on my kindle. It might make a difference as to which version of the kindle you have because the way you do this almost certainly depends on that. It may lead to more more helpful answer if give the version of the kindle you have.
see this video Just two examples !
23.June.2015
Jun 23, 2015 | Amazon Kindle 1
My sound on my kindle fire hd is not working, only if I have earbuds, headphones, or speakers plugged into it
Sounds like it should be returned, if still able to. There is most likely a cold solder joint or wire, but i dont believe it is user repairable.
Oct 22, 2014 | Amazon Kindle Fire HD
How can I get my player to connest to my bluetooth headphones have tried several times no luck
If you have a Kindle Fire or later this is possible. Any Kindle before this model has the hardware for BT, but not any method to access the BT (bad on Amazon\'s part, but that\'s the way it is).
Kindle Fire do this: Go to settings --> Wireless --> Bluetooth Turn on Bluetooth if it is not on.
Now on your headset put it in pairing mode. Instructions on how to do this should have come with your headset. Once in pairing mode press Pair a Bluetooth Device on your Kindle. Your Kindle should "see" your headset and list the name of it under PAIRED DEVICES.
You only need to pair the device once. Then you should be able to press the device name and if the device is near by and on it should connect to the Kindle.
HTH
Jul 31, 2014 | iLive IHB603B Micro Bluetooth Stereo...
Kindle, stuck in sleep mode
How to Reset Kindle - courtesy Andrei Pushkin
Kindle DX, Kindle 2 or Kindle 3: This is easy - just hold the power button (next to the headphone jack) for 15 seconds and the device will reboot.
Reset Kindle 1: This is trickier as you'll first have to remove the back cover; you'll also need a paperclip.
Read more: Reset Kindle
Jan 29, 2014 | Amazon Kindle Wireless Reading Device
My kindle's volume doesn't work at all in headphones or off headphone. I downloaded app but it still doesn't work.
Restart the FIRE (Press and hold the power switch for a count of 20)
Now start normally - if not cured call Amazon and expect a free replacement to be sent to you.
Sep 19, 2013 | Amazon Kindle Fire HD
Downloading books
If you have the 3G model of Kindle then you can download books using 3G which is like you would use with a mobile phone.
If you don't have 3G then you will need to connect to a WiFi network in order to download books directly to the Kindle. See the Connecting With WiFi Guide for details of how to do so.
You can also transfer books directly from your PC to your Kindle using a USB lead - see the video guide on how to do this.
Dec 26, 2011 | Amazon Kindle 3G
Does the KImble have an output socket so that the audio (talking) feature for books can be used through the car audio system
The Amazon Kindle has a headphone (3.5mm) jack which can be used to listen to audiobooks - a male-male extension cable can extend this to allow the output to be played through another medium, if your car has the same size jack. If not, there are some products which will broadcast the audio on a low-grade radio frequency with roughly the range of your car (for example: http://www.amazon.com/Transmitter-Kindle-car-power-cable/dp/B0020KKWLK), allowing you to listen to your ebook on a particular radio frequency.
Hope this helps!
Mar 26, 2011 | Amazon Kindle 2
Sony mdr-v700dj Headphones needs new cord! The cord was sliced in half in the middle. The headphones are practically brand new. Is there a way to replace the cord?
All you need to do is solder a new plug on to the end of the remains of the cable coming out of the headphones, then buy an extension lead. It will be much easier than replacing the entire lead, as getting into headphones is a very tricky thing to do.
Feb 10, 2010 | Sony MDR-V700DJ Professional Headphones
How to hookup kindle to car audio system
This could be either very easy or a huge headache.
Easy way - The newer cars have an audio input jack, basically a headphone jack (1/8"). There are cables that you can use with 2 male connectors; one on each end. Set your car radio on AUX/LINE IN/MP3 and turn it up.
Hard way - Go to Radioshack or Best Buy, even Target or Wallmart, and buy an FM Transmitter. They shouldn't run over $20. You plug it into you cigarette outlet for power and/or takes 2 AA batteries. Plug the headphone jack into your Kindle and set the radio station on the transmitter to either a very low or very high radio station; somewhere where there is no station close by. Turn the car FM radio to the station you set it on and turn it up.
Sep 18, 2009 | Amazon Kindle 2
176 people viewed this question
 Grubhead
Grubhead
