Question about Ariston Platinum Line AWD129 24" Washer/Dryer Combo with 13 lbs. Maximum Load Capacity, 1200 RPM
Hi. I have an Ariston AWD129 washer dryer combo and it is leaking during the washing cycle. What are the possible causes and/or parts to fix? Thanks.
  • Ariston Master
  • 5,323 Answers
FIRST HAVE TO DETECT FROM WHAT AREA IT IS LEAKING B4 WE CAN HELP? PERHAPS A HOSE OR CLAMP CAME LOOSE. ETC
Posted on Apr 09, 2015
Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
I have an ariston washer dryer combo. today I turned it on to do a wash cycle. the knob no longer clicks or shows the times of other cycles. I've turned it off and on a few times but nothing helps
Ariston armf 125 washer dryer combo - YouTube
? 4:14
www.youtube.com/watch?v=zPtG5Q3qQ3Q
Oct 23, 2010 - Uploaded by troykm Rinse cycle. Correction - it does do 3 rinse cycles!! :-)
[PDF]Instruction Manual - Ariston Appliances
aristonbrand.com/media/WDG-8629-User-Manual-19510586801_AU.pdf
WASHER-DRYER ! This symbol reminds you to read this instruction manual. ... from its packaging. 2. Make sure that the washer-dryer has not been damaged.
Sep 22, 2015 | Washing Machines
Supra washer/dryer combo leaking significantly
In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Mar 20, 2013 | Supra SW5L65D Front Load Washer / Dryer
I cant start washing machine as red light buttons are stuck
Possible that the program controller unit is faulty and so there is need to check the voltage on the controller to confirrm the fault.
Mar 18, 2011 | Hotpoint Ariston AWD129 Front Load...
Rinse cycle
If the machine has a soak cycle, you can use that. If it does not, you can have it fill on a cold rinse, and then stop it for a soak. Restart it on a hot wash with a cold rinse. Tumble dry low.
May 14, 2009 | Ariston Technologies AWD 129 NA Washer/...
Will a new handle fix our problem?
Thanks for responding back.
We decided not to go for the dryer.
thanks again.
Jan 20, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Problem tripping GFCI
GFCI units go bad with regularity , I would replace it first.
washer manufactures usually put the schematic inside taped to a side panel.
open the top panel and see if you see a plastic bag along the sides.
the site for this washer did not have any info or manuals online right now.
Feb 07, 2008 | Ariston Technologies AWD121WH
Ariston Platinum Line AWD129 24" Washer/Dryer Combo with 13 lbs. Maximum Load Capacity, 1200 RPM Logo
114 people viewed this question
Top Ariston Dryers Experts
Are you an Ariston Dryer Expert? Answer questions, earn points and help others
