How do I fit a drum paddle to beko wma 767s
I have the new paddle but there is a metal part in the drum that has part of the old paddle trapped behind it,looks a retaining device but it won't budge.
  • 998 Answers
The paddles are normally fitted from inside out of the inner tub. You will have to strip the whole machine down to remove the inner bowl and then you can get to the fitting which holds the paddle in place.
Posted on Apr 09, 2015
  • Steve wilson
    Steve wilson Apr 09, 2015
    Thought as much,thanks for your help Steve.I a'int doing that so i'm going to measure and drill an access hole in the drum casing,then silicone it back afterwards.It's done it's work so if it fails it fails,i'll post the outcome.Cheers! SW.
My beko washer is only six months old its washed all day. On last load it has started to make a loud metalic noise while emptying and spin its like something is stuck but filter empty
Is it out of warranty?? It sounds like the washer drum bearing failed. Do you use approved super low suds detergent? You can not use regular detergent it will corrode the drum bearing.
Jun 01, 2016 | Beko Washing Machines
I have a Hotpoint AQXXF149PM washing machine, and two of the drum paddle lifters have fallen out.I have the replacement parts but cannot work out how to fit them, as a piece of metal projecting at 90...
I have exactly the same problem on my ...129 model. I'm a mechanical engineer and looking at the design it apears that these aren't designed to be replaced. The 90 degree tab looks to be only accessed from the outside of the drum so can only lock the tumbler in place from the factory. It needs to be bent flat to get the paddle on!
I hope someone can prove me wrong??
Jun 24, 2010 | Hotpoint Ultima WF860 Front Load Washer
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint WD860
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Aug 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
