Question about Electrical Supplies
Manual for Hitachi W6VB3SD
Need manual for operation manual included was not thorough Has already been ordered but looks like 2nd screw interferes with one being applied to deck
  • 998 Answers
HOW TO REPAIR THE CABURETOR
Some carbs are simple and some complex but both should be treated the same way.
Remove the carb and thoroughly wash the outside before turning each adjuster screw in and carefully counting the turns until it bottoms (eg 2.75) so the screw can be returned to the original position.
Most carbs need only thorough cleaning and few, if any, new parts.
The carb should be systematically and completely dismantled making drawings and notes during the process and then each component is thoroughly cleaned ensuring all air and fuel passages and jets are clear and use the reverse process to reassemble.
During the cleaning process each component should be examined for wear or damage using a magnifier and replaced if necessary. It is usually wise to replace the float valve and any flexible diaphragms but this isn't always necessary. If water is found inside the carb the fuel tank should also be cleaned.
Jun 29, 2017 | Cars & Trucks
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
Hitachi External Hard Drive 500 g where do i get the driver for it ?
This is what I get from Hitachi about the USB drives:
The External USB Storage and Portable USB Storage products do not need additional drivers to function in WinXP/2000/Vista, or the Mac system 9.2.2 or OSX. These operating systems already include the drivers needed for USB storage devices.
Looks like you don't need a driver. This is what I expected.
Feb 02, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
I need a driver download for a hitachi hard drive model HDP725050GLA360 where can i find one?
Current operating systems, including Windows 7, Vista, XP and 2000, and Mac OS X, already include pre-installed drivers for the hard disk drive itself. No additional drivers are required.
If your system is requesting drivers, you may need current versions of your controller or motherboard drivers. To obtain the most current controller or motherboard driver, go to the respective manufacturer website.
Oct 26, 2009 | Computers & Internet
To replace a bulb in the Hitachi CP-S235 LCD Projector, do I just unscrew the two screws under the plate underneath the machine? Are there any precautions I should take, like not handling the bulb? I have...
Yes to replace the lamp you need to remove the 2 screws. You can touch the lamp but I try not to. After the lamp is in you need to reset the hr timer for the lamp. to do this you need to look in manual on page 34.
If you do not have the manual you can get it here at link below.
http://www.aboutprojectors.com/pdf/hitachi-cp-s235-manual.pdf
Good luck
Oct 05, 2009 | Hitachi CP-S235 Multimedia Projector
I was moving my 65' hitachi tv and the wind busted the screen
You can buy the replacement screen from www.searspartsdirect.com I ordered one for mine the part number is UX26083. When you order look for online coupon codes because I got 20% off of mine when I ordered and came out to $300 with shipping included.
Jul 11, 2009 | Hitachi 65S500 65" HDTV-Ready Rear...
HITACHI 43UWX10B I NEED REPAIR MANUAL
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Good Luck, big IRISH.
Sep 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Electrical Supplies Logo
313 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
