Question about 2005 F350
Front park lights not working turn signals work need to know how to fix the problem on my 05 f350 powerstroke
    Sergeant:
  • 303 Answers
If it's not a fuse it's the bulb some of the front lights use a double filament like the rear lights the parking light filament is probably burnt out or a fuse is bad from use or a short in a wiring harness somewhere
Posted on Nov 05, 2015
SOURCE: Parking Lights Not Working
Have ypu checked the fuses under the dash? These are located under a removal panel above the brake pedal.
Posted on Jun 23, 2008
Ajkill
  • 2035 Answers
SOURCE: Tail lights/front parking lights don't work.
Please use this link:
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800c4326
Good luck..
Posted on Jul 16, 2008
MrScary66613
  • 1990 Answers
SOURCE: 99 ford f350 powerstroke cruise control
There actually is a Fuse and a Relay for this. There should be a Fuse in the Cab Fuse Box and a Relay in the Fuse Relay Box under the Hood. These are where I would start.
Posted on Jan 25, 2009
  • 75 Answers
SOURCE: 99 Ford F350 Powerstroke diesel; misfire code; loss of power
The first thing i would check is the Glow Plug Relay. Depending on your engine there should be (2 solenoids, or just one) sitting on the top front a little to the right of center. (right bank of engine that is) If you have 2 of them one should be smaller and it is the one furthest to the rear of the engine. It controls power to your glow plugs for cold start up. When you turn the key to the on position the 2 larger wires should both have power. When the ignition is off only one wire should have power. Check this if you do both these tests and only one wire has power with key on or off then you need to make sure that the key switch is sending power to the solenoid. Do this by checking the smaller wire with key off. It should not have power and then with key on it should have power. If this is good and test one is bad then the relay is bad. Note This is not true for the larger realy that sits furthest foward on the engine. The bigger one. This test will not work for it but it controls your intake heater. On another note: This is a timed circut and will "kick out" after about 1-2 minutes. In otherwords it does not stay on all the time that key switch is on it will for for about 1-2 minutes then shut off! Next would be your injectors are getting weak or bad and even your HPOP could be getting weak. or glow plugs in engine are out, In otherwords there are alot of possibilities causing your problems If you are getting a misfire code for your injectors then you may have some weak or inop injectors. Any way this will give you a pretty easy test for the most common failure which is the Glow plug relay. About 35-40 bucks at your local auto parts house.
Posted on Feb 03, 2010
alicantecoli
  • 22326 Answers
SOURCE: f350 dash lights and tail lights not working turn
either a switch problem or a fuse ,power supply is down somewhere?? BUT WHERE
Posted on Sep 03, 2010
What number fuse is the brake and turn signal lights on 2006 F350
F2.27 is for turn and brake light, located in the fuse box under the steering column. Hope this helps
Feb 11, 2018 | Cars & Trucks
My 2008 f350 cab and Chasse front blinkers work but my back blinkers and brake lights don't work
brakes and turn signal lights work together not tail and turn your mistaken
Jul 15, 2017 | Cars & Trucks
I have a 2001 Pontiac Montana and none of my lights in the back work . I dont know.what it may be and dont know how to fix plz help.
If none of the lights in back work, it sounds like something happened to the main wiring harness. Which is probably beyond your ability to repair at home.
If the parking lights and turn signals work in front you know the fuses are good, so they should also work in back.
The parking lights, turn signals, back up lights and brake lights are on 4 different circuits.
Nov 21, 2015 | Pontiac Cars & Trucks
2003 ford crown victoria with working brake lights but no parking or rear lights
Duplicate the issue ? You mean the lights are working now ?
The turn signals and brake light circuit is one and the same. The parking lights are on a different circuit. The parking lights get power from the headlight switch and don't travel thru the turn signal switch.
So have you checked the park fuse for power ?
The location of the fuse should be in your owners manual.
Feb 15, 2014 | 2003 Ford Crown Victoria
1995 f350 powerstroke wont start one other time had to drop shifter and put back to park before it started now it wont start the lights elect windows and glow plug cycles but no clicking noise just nothing
replace the transmission range sensor. Adjust the new sensor by loosening the bolts slightly, turning the key on, putting the truck in reverse, and turning until reverse light come on.
there are 2 possible sensors, depending on which transmission you have.
Oct 06, 2011 | 1995 Ford F350
2002 f350 powerstroke, keep blowing fuse #45. seems to blow when i shift out of park, or could be when i release the park brake.
The wire from you shifter overdrive button rubbed and will ground but not everytime. The truck will idle but you will have only a idle. Open the top cover and you will see the bad spot, Fix or replace and you are good.
Oct 28, 2010 | 2002 Ford F350 Super Duty DRW Reg. Cab
1996 f350 powerstroke dies while running, like turning key off.
if it has a 7.3l then try the cranksensor it,s right on front of engine beside harmonic balancer on the passenger side they are notorious for this and aren,t expensive to replace hope this helps
Jul 13, 2010 | 1996 Ford F350 Crew Cab
'05 Chevrolet Malibu - Front Right Blinker is not Working
You need to check for power coming out of the turn signal switch with a test light, or voltmeter. On older Chevys, the R/F turn signal wire is dark blue. Check the color of your wire at the bulb socket, then locate the turn signal switch connector, and probe that color wire with the ignition switch on, and turn signal switch in the right position. If you have power coming out of the T/S switch, you have bad connection, or open circuit between it and the bulb socket.
Sep 01, 2009 | 2005 Chevrolet Malibu
All lights not workin
check the turn signal switch... purchase one then plug it in under the steering column first then check them...if all lights work, change the switch out..if not , take back and tell them it was not installed and you dont need it
May 13, 2009 | 2000 Ford F350 Super Duty Super Cab
2005 F350 Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
