Question about JVC RX-8010V Receiver
I have a JVC Surround system but left speaker does not sound when S.E.A is turned on
When I turned off the S.E.A. it sounds o.k., technicians informs that this could be a malfunction of its configuration system, tell me your answer.
  • 20 Answers
SOURCE: my jvc rx-6010v is OVERLOADING?
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (JVC - and others - say SIX ohms, but 8 is the "standard" you should use.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: The internal overload protection system you mention is designed to help prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized JVC service center must do this. Note, though, that if you have attempted to "cheat" the system several times, damage CAN be done that requires servicing.] But, before you take the unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Posted on Jul 18, 2007
  • 93 Answers
SOURCE: JVC receiver
Did you check impedance value and wattage on speakers you want to add to receiver?
Posted on Oct 03, 2007
dna_killer
  • 34 Answers
SOURCE: JVC Surround Sound System
The problem on your sub is your speaker is faulty the end of the speaker coil is burnt so at a certain volume it`s makes a short .I hope that would solve your problem:)
Posted on Jan 09, 2008
terribleteac
SOURCE: No Prologic Surround Sound
im thinking the reciever is set to get its audio from somehwere other than the dvd, sounds like you did most of the troubleshooting but do you get audio out of the reciever if its just playing the radio or something other than a dvd?
Posted on Feb 13, 2008
SOURCE: JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Posted on Apr 10, 2008
I have only a speaker to a jvc sp-pwm505 surround sound system. But am looking to power it using something else. Is this possible?
Yes, all speakers operate on the same principle. Though depending on the resistance of the speaker, usually 4 or 8 ohms, it may place too large a load on the source driver. Try it and see.
Nov 25, 2014 | JVC Audio Players & Recorders
How to connect my JVC Audio/video control receiver digital surround sound system
Need to know how to set up a surround sound system? It's fairly easy, with the right equipment. Surround sound gives you that "theater" feel in your own home.
For more information on optimizing the sound of your chosen system visit:
http://www.ehow.com/how_3393_set-surround-sound.html.
To set up a surround sound system go to:
http://forum.ecoustics.com/bbs/messages/34579/219978.html.
Additionally,Some people prefers a wire diagram to connect their surround sound system. The basic concept to connect any audio system is to follow the path of sound from its origin to its final output stage, either headphones or speakers. There are other basic premises to follow, such as the impedance of the speakers and the output of the amplifier, but the concept is to start with an input and terminate each input to an output somewhere on the amplifier unit.
A wire diagram shows a picture that represents where each of these wires would go in considerably little detail. One example would be that a television set starts with a signal from somewhere, broadcast or cable, and comes out of that antenna and goes into the surround sound amplifier. The sound is processed in some way and the video is output to the television set and the audio is output to the speakers or headphones. Although complicated in textual from, most find that a wire diagram is much easier to follow.
For an example of a wire diagram for a surround sound system visit ..
http://www.crutchfield.com/.
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 23, 2011 | JVC Televison & Video
I would like to use my jvc home theater while watching tv. But i have no idea how or what wires to use to make this work.
You will need a 2RCA to 2RCA audio cable as shown below. Connect the audio out socket of your TV to the Aux or TV/SAT input of the JVC. When you want to hear the TV sound through the JVC system just select the appropriate input on the JVC. If you want the surround speakers to work, select ProLogic or All channel stereo on the JVC's surround settings.Because by default the radio or TV sound is only stereo, so only the front left and right speakers will work. PLII will convert 2 channel to 5.1.
Apr 26, 2011 | Audio Players & Recorders
Problem with surround sound on JVC Th-C5 sound system
Not sure how you're hooked up or what model TV you're using. If you mean the TV sound through RCA cables is the source and you're wondering why it's not surround. Well, it's not multichannel. Please fill in some details.
Dec 25, 2009 | JVC TH-C5 System
What is wrong with my theatre system?
have you tried all the sound settings from your dvd player? i have a 'sound' button to change from raw to surround etc. Press buttons and try it.
Some dvd's dont have the channel outputs, so try it listening to classic fm or radio 1.
AndystUK
Aug 30, 2009 | JVC THS55 System
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
No sound from all speakers except front left and front right
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Jan 24, 2009 | JVC TH-G30 Theater System
Rear Surround speakers
Best thing to do is to put the unit in 5 channel or 7 channel mode. That will send left ch information to the front left and rear left speakers ( both will get the same information). Ditto with the right channel. The center channel will get centre channel information.
If all the speakers work, go out and rent TOP GUN. ( yes its old), BUT there are a few extreme scenes , one of which is the elevator scene, where the camera changes perspective and suddenly you hear the elevator doors close BEHIND you through only the surround speakers ( have the unit in surround mode....NOT 5 or 7 ch mode ). If this works ok, then you have no problems.
Remember, surround sound only produces information in the rear channels when the information is there. To check out the digital and DTS decoders, get an action flick. If you can, get a remote too, because that will unlock many features about the receiver that you cant get to with the front panel controls. Also go to yamaha and download the owners manual ( its free !!).....that should get you going.....
best of luck...
Rob
Jun 08, 2008 | JVC RX-880V
Dec 29, 2007 | JVC SP-PW100 Subwoofer
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
JVC RX-8010V Receiver Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
