Question about Panasonic Lands Phones
One of our extensions panasonic KXNT560 looks like it is not turned on except for a green light on the message bar. Tried to reach the extension from another phone my screen says Reorder Tone.
Phone out is panasonic KXNT560; phone trying to connect panasonic KX-NT543; power was out but back on.
SOURCE: Panasonic Kx-T123230 extension to ring
hope this help...
with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
Posted on Feb 17, 2008
cnavarro
  • 2460 Answers
SOURCE: panasonic KX - T7436
Someone has to answer the Message Waiting call to cancel...or, try dialing 700 plus your extension to cancel ALL MW lights.
Carl
Posted on Sep 03, 2008
cnavarro
  • 2460 Answers
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
Posted on Jan 21, 2009
cnavarro
  • 2460 Answers
SOURCE: lock extension with my Panasonic KX T7730
Do you need the default lock code because you already did this, or is it locked and you can't unlock it?
This is probably close, but in the American version it's 77 lock lock # to set and 77 lock # to release, where lock is a 4 digit number.
The System manager can release all locks from their phone. You'll have to make arrangements with an "engineer" to get those codes.
Carl (working on Br terms)
Posted on Jul 18, 2009
cnavarro
  • 2460 Answers
SOURCE: KX-T7433 - message light does not work
Assuming that the 74xx phone is connected to a Panasonic TD system, the only code is dialing 701 on the intercom, or pressing the MESSAGE button and dialing the 3 digit extension. You can't set your own MW, so you need to do it from another phone to your extension to test it. It also has to be the hardware number ie 101-116 or 132 and not Phantom numbers.
Your 74xx phone could be connected to a TDA or the numbering plan may have been changed, but those are obscure situations.
Carl
Posted on Sep 01, 2009
Panasonic vb-44223-g the light is on
Normally this is the Voicemail indicator light. If you have a button programmed for voicemail you can push that button and if the system calls the VM system it should clear after you listen to the message.
Another way the light can get turned on is if the system call back feature got activated. If this is the case you just need to call the station that called you and turned on your light. Again if you have a message button this will call that extension in the office. Once they pick up the phone the light should clear. Worst case you can try calling every extension in the office and eventually you will find it.
One last option is if the phone is connected to a PBX model 576 or HD576 (This is the brain box in the closet or basement) you can dial *4 plus your extension number or *5 plus your extension number are the default message light codes. One code says turn on the light the other says turn off the light. If your system is an older system 40, 72, or 96 this will not work.
Best of luck!
Jan 03, 2014 | Panasonic Vb-44223-g Dbs Display Year...
My message light will not turn red so I am not aware that I have a message. If I push the "message" button, it is busy
You are missing a lot of information, but here goes. Your message light is unlikely broken in a new phone. Have someone ring your extension and press "4". Now look at your phone and press MESSAGE. The display tells you who left the message and you get 2 options on your soft keys to call or erase the message.
Now, here's the part you left out. What is leaving the message? It could be coming from CO based voice mail, a TVA system, or a SVM card. If it's a TVA voice mail system, it has to be programmed with your mailbox and extension (usually the same). A message left in the General Delivery Mailbox doesn't light anything unless it's programmed to do something, and a message left in your box usually works if it's properly set up to begin with. We try to set up our TDA's to eliminate GDM messages, so that means that Call Forward lights must be lit at every extension that needs voice mail and there's always a choice to direct callers to extension 101 or some other mailbox but the GDM. If it's CO based, you bought the wrong system, and an SVM card has a set of instructions to assign extensions to slots.
Most likely you'll find the missing information in the Programming Manual of the voice messaging system.
Carl
Jan 11, 2011 | Panasonic KXDT333 Phone
When i push the intercom then message button to retrieve messages it tells me invalid across the screen
while the handset is hung up (without pressing the intercom button) press the "MESSAGE" button, on the display it should show ~why~ the message light is on (cause it is possible someone tried to intercom you, then hit the wrong button) after that you can turn off your light by pressing:
1) INTERCOM
2) 700
3) *your extension #*
it is possible that the extension that turned on your message light is no longer in service, making it an invalid extension
Jan 06, 2011 | Panasonic KX-T7431 Corded Phone
How do I turn on my message waiting light?
Why would you want to? Technically, I can turn on someone else's MW light in 2 ways, by calling them and dialing a "4", or by dialing *701 plus their extension number. That also means the equipment that's turning the MW lights on your phone has to do the same thing.
Before you ask, pressing the MESSAGE button and looking at the display where a soft key lets you CLEAR the message works, and *700 plus your extension clears ALL messages.
Carl
Oct 26, 2010 | Panasonic KXDT343 Phone
We have a KX-TA624 phone system connected to a TVS50 voice processing system. I have one user who has a KX-T7730 phone and his message button wont light when a voice message is left for him. I know the...
The user may have brushed onto the 62x commands to change or turn off message notification. From the subcriber's mailbox, choose option 621 and make sure it's enabled, then 622 and make sure you're using option 2. (continuous). If neither of these work, have the owner log into mailbox 999 and make sure that the owner's extension of the broken extension matches the extension. That's option 611 mailbox number and follow the prompts. The extension is the mailbox.
Carl
Aug 05, 2010 | Panasonic KX-T7730 Corded Phone
Carl
Sep 01, 2009 | Panasonic KX-T7433B Corded Phone
Message Lamp does not light
This will be a two step answer. Walk to any other extension and dial *701 plus the extension that doesn't work. If it lights the message waiting lamp (of course it will), then please look for your voice mail system cabinet. It may be black, with a dark blue cover the same as the TDA phone system. Part numbers would be TVA-50 or TVA-100.
If all of the above is true, you need to do some notification programming in the voice mail system. Do you have the programming software if it's a TVA?
Carl
Dec 22, 2008 | Panasonic KX-T7630 Corded Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Panasonic KX - T7436
Carl
Sep 03, 2008 | Panasonic KX T7436 Corded Phone KX-T7436
Lands Phones Logo
63 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
