Question about Depo Auto Parts Saturn S Series New A/C Condenser Cooling Fan Assembly-Shroud Blade Motor 1995 1996 1997 1998 1999 2000 2001 2002
Hello, i am trying to disconnect the horn via the fuse box. Where would i find the horns fuse in the box?
Hello. Horn in 03 Monte Carlo isn't working. Replaced both fuse and relay. Removed and checked the horn and it still sounds but no results. Please help.
Find a facility with a scan tool that can access the Body Control Module. They will need to look at the data. Ideally the scan tool will have bi-directional control. You should be able to watch the horn be pressed via the scan tool in the Body Control Module. If you can see it is pressed, but no horn sound, try to operate the horn via the scan tool. GM supports this functionality test. If the horn does not operate, check the horn relay. It could be a broken wire between the BCM and the fuse box, or between the horn contact switch and the BCM.
Mar 06, 2017 | 2003 Chevrolet Monte Carlo
Witch fuse should be pulled on 1999 jeep to stop horn from blowing
Your owners manual will show you exactly where it is...However it is easy to disconnect the horn...You desperately need a horn for safety reasons to avoid a crash...Especially if your state has a safety inspection requirement...Your fuse panel should also have the fuses numbered and a sticker inside the fuse box cover stating which fuse goes to horn....Also you can wear safety glasses and disconnect the battery to avoid air bag explosion..Remove steering wheel center cover where the horn is pressed...,You will see a small wire attached to the cover and to the prong inside steering wheel...It could be loose or disconnected.....If not just disconnect the wire and black tape the terminal end ..Then the horn is disconnected...
Feb 20, 2015 | 1999 Jeep Cherokee 4WD
Were to find horn fuse
different cars different places. look on back of fuse cover it is either on inside fuse box, or under hood fuse box. if the fuse is ok! check the relay for the horn in under hood fuse box. if that is good.disconnect wire from horn, run a wire from battery positive to the horn it self, if it works now, it is the horn relay or button in car. Good-Day!
May 11, 2014 | Chevrolet Caprice Cars & Trucks
Horn relay
my guess, its a dead horn? both dead?
no actual question asked????????
the fuse is blow? in fuse box, eng. bay box.?
if no power to horn, (voltmeter)
we check power in and out of relay if there is one.
then at the horn button wire, (air bags can kill any mech. defeat them
first if heck bent to fiddly steering column parts in any why)
all this info is convered in in the FSM, get one. or login to alldata dot come. and read it.
here, ill look at yours. now.... a fast look.
ok 2 horns, hi/lo, and 1 relay in the under hood fuse box.
it should be labeled in the box, HORN
the relay can not work if the fuse is blown
or the horn enable line is dead. button.
the button grounds (0v) the relay via wire color lt.green-blu pin a11 on relay. if the a11 is at 12v the fuse is good.
if you push the horn button this A11 goes from 12v to 0v, and the relay energizes (click) and the horns both blow.
if no power makes it to the horns, the relay is bad no 12v
if by chance the relay output to horns go to 12v, then the horns are both dead.
Oct 05, 2013 | 2003 Honda Pilot
2000 chevy blazer horn doesnt work
check fuse box inside of car also fuse box under hood too..find ur horns and if possible u can reach the wire thats plugged into each one disconnect them 1 at a time get another wire long enough too reach ur battery connect 1 end to horn with other end of wire gentl touch battery positive terminal horn should sound if bothe horns sound u have a fuse blown..
Aug 16, 2013 | 2000 Chevrolet Blazer
How do you disconnect horn on 1989 Jeep cherokee pioneer?
The horn may be on fuse number 14 which is in the middle of the fuse box. Or it may get power from the key switch. The horn relay is to the left of the fuse box or in the engine compartment.
The easiest way to kill the horn is to unplug the horn itself.
Jul 24, 2013 | Cars & Trucks
My Horn Isn't Working
It could possibly be the relay itself or the horn. To test connect power straight to the horn, if it goes off then its the relay if not then its the horn.
Jun 28, 2013 | 1997 Chevrolet K1500
The horn won't work checked fuse and it was okay, where is the horn located at?
Most likely you will need to replace the horn relay located in or near the main fuse box or under the hood in the high amp fuse box. If you have the owner's manual it will show the fuse box diagrams.
Feb 25, 2011 | 1990 Honda Civic
Electical
You may have some short circuits in your wiring, a bad horn relay or horn unit, and/or a bad wiper motor. Hard to tell without actually looking at it.
Try this:
Disconnect the horn, and try another fuse. Does it blow? If not, the horn is shorted, and needs replaced. If it blows, remove the horn relay & try another fuse. Same with the wiper motor, unplug it and try another fuse. If it does not blow, you need a wiper motor.
Sep 26, 2008 | 1985 Toyota 4Runner
1999 toyota corolla Horn doesn't work.
Usually the wire from the steering wheel is Green w/Red and the wire to the horn from the fuse box is White. There is only one fuse, sometimes shared with the emergency lights. Check to see if there is power to the horn itself with a volt meter.
Aug 25, 2008 | 1993 Toyota Corolla
Depo Auto Parts Saturn S Series New A/C Condenser Cooling Fan Assembly-Shroud Blade Motor 1995 1996 1997 1998 1999 2000 2001 2002 Logo
261 people viewed this question
Top Depo Auto Parts Computers & Internet Experts
Kar Volk
Tom Chichester
David Ellis Rhea
Are you a Depo Auto Parts Computer and Internet Expert? Answer questions, earn points and help others
