Where are all of the possible locations for the graph of (x, y) if x = 4?
  • 645 Answers
If x = 4, y can be any number. What you get is a vertical line going through (4,0). If you are talking around domain and range, D= {x=4} and R={yER}.
Good luck.
Paul
Posted on Apr 08, 2015
When I try to graph it says argument error
Your function is not correctly defined. If graph is function y=f(x), variable must be x; if graph is polar, variable must be theta, and if graph is parametric, variable must be t. This does not cover all possible cases. Check the graph type and the definition of the function.
Mar 16, 2015 | Casio FX-9750GII Graphing Calculator
Help with Ti Inspire Cx calculator. It rounds up the coordinates when graphing
Draw the graphs of the functions you are interested in. While the graphs are displayed Press the Menu key. In the drop down window locate the sub menu Settings (number 8 or 9) depending on your calculator
The following screen is displayed with at the top the setting Float.
Follow the right pointing arrow on the same line as float and select Float 3 or 4 as on the screen capture that follows
Point to the graph of one of the functions select it then press the menu select option Analyze graph then intersection.
You will be asked to select the second function, then the lower bound and upper bound. As you see on the previous screen capture, the coordinates of the intersection point are given with 3 decimal digits.
Apr 27, 2013 | Office Equipment & Supplies
HELP WITH TI INSPIRE CX calculator
Draw the graphs of the functions you are interested in. While the graphs are displayed Press the Menu key. In the drop down window locate the submenu Settings (number 8 or 9) depending on your calculator
6d8395f7-b10e-4d9e-a7e6-45beadb303a3.jpg76f72147-9dcf-457f-a122-ae70490e2815.jpgThe following screen is displayed with at the top the setting Float.
eb304039-5513-442e-886f-d435de8aa653.jpgFollow the right pointing arrow on the same line as float and select Float 3 or 4 as on the screen capture above.
0c4e79fb-d2eb-4461-821f-87adbd63b387.jpgPoint to the graph of one of the functions select it then press the menu select option Analyze graph then intersection. You will be asked to select the second function, then the lower bound and upper bound. As you see on the previous screen capture, the coordinates of the intersection point are given with 3 decimal digits.
Apr 27, 2013 | Texas Instruments TI-Nspire Graphic...
How do I graph y=4/5x -1 (where 4/5 is 4 over 5, not 4 divided by 5)
Before trying to graph anything lift the ambiguity from the expression. That is what parentheses are for. Besides, there is no difference between 4 over 5 and 4 divided by 5. They mean the same thing.
Look at the screen capture and see how many possible interpretations you can have for your expression.
Use parentheses to enforce your intention.
4/5X-1 gives the first expression on display.
4/(5X-1) gives the second expression
4/5X^-1 gives the third.
To graph, press the MENU key then use arrows to focuss on GRAPH. Press ENTER/EXE
In the Y= editor type in the intended expression after Y1= and press EXE.
Press DRAW.
Aug 21, 2011 | Casio FX-9750GPlus Calculator
I am getting ERR:ARCHIVE 1:QUITE when I try to
I tried all possible situations where one would get an error ERR: ARCHIVED 1:QUIT 2:GOTO in relation to graphing, and I was unable to do so. Thus I cannot explain your error (in relation to graphing). I conclude that the error is unrelated to the graph.
As a general rule, one you get message ... 1:Quit, 2:GOTO press 2 and you will be shown the location where the offending symbol is.
Anyway, to graph functions, always deactivate the statistical plots
  1. Press [2nd][Y=] to access (STATPLOT) then press [4:PlotsOff]
  2. Command PlostOff echoes on main screen.
  3. Press [ENTER], calculator answers Done.
  4. Open the [Y=] editor to enter your function and
  5. Press [GRAPH].
  6. If you do not see any graph,
  • press [ZOOM][6:ZStandard] or
  • adjust the window dimensions by
  • pressing [Zoom] and
  • setting the Xmin,Xmax,Ymin,Ymax values
  • making sure that Xmin is less than Xmax, and Ymin is less than Ymax.
Feb 28, 2010 | Texas Instruments TI-83 Plus Calculator
When graphing the calculator only allows me to graph on function. When typing in a new function the first function that was highlighted became unhighlighted and only the new function is highlighted now.
If you ran the dynamic graphing application called Transfrm you will only see one graph. It takes over the graphing from the native OS.
You will recognize it by the graph style at the left of the Y1=, etc. as in picture
As you can see, only one = is highlighted, meaning only Y1 will be drawn. To recover the native Y= screen, you must unload the Transfrm App from memory.
Here is how to do it.
Exit what you are doing and go to main calculator screen.
Press the Apps button.
Scroll down to find the Transfrm App
Highlight the : before the name and press ENTER.
The screen appears as on the second screen capture above
Press 1:Uninstall
This will unload it from memory and you will be able to draw multiples graphs.
There is the possibility that the failure to draw multiple graph has nothing to do with Transfrm. In that case it is most likely due to the Stat Plots being turned ON. Turn them OFF
Press [2nd][Y=] (STAT PLOT)
Select [4:PlotsOff] and press [ENTER]
Dec 30, 2009 | Texas Instruments TI-84 Plus Silver...
When I want to plot more than 1 graph, and I go to the window, I only see one of them, instead of all of them at once, how can I fix this?
If you ran the dynamic graphing application called Transfrm you will only see one graph. It takes over the graphing from thge native OS.
As you can see, only one = is highlighted, meaning only Y1 will be drawn. To recover the native Y= screen, you must unload the TransfrmApp from memory.
Press 1:Uninstall
Dec 24, 2009 | Texas Instruments TI-84 Plus Calculator
Graph and trace buttons don't work
If either error occurs when trying to graph a function (not a STAT PLOT), the error can be corrected by turning off the STAT PLOTS. The following steps will turn the STAT PLOTS off, allowing the graph of the function to be displayed.• Press [2nd] [Y=] to access the STAT PLOTS menu.
• Select 4: PlotsOff.
• Press [ENTER].
• Try graphing a function like y = x^4-3x^3+6x-1
Jun 03, 2017 | Texas Instruments TI-84 Plus Calculator
"graph" on reviewed pictures
Press up or down on the 4-way command button to toggle between histogram, shooting info, custom settings, highlights, or none.
May 13, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
79 people viewed this question
k24674
jasbo
jasbo
