Question about Compaq Evo Workstation W6000 PC Desktop
What is the purple wire from power supply to the motherboard?
    Master:
  • 301 Answers
Am not sure which power supply you are using
Howto Set up Motherboard and Install Power Supply
Posted on Apr 08, 2015
I have a Clarion car audio system. I want to use it as an outdoor system on 120v. What kind of power supply does I need? Does something else should I take care of?
Car stereos require power for both red and yellow wires. You can twist them together, then black for ground. Not sure about your power supply setup. A standard ac to dc should work. Run speakers externally. Usually white and grey wires are front left and right and purple and green are the rear. good luck
Jun 15, 2016 | Clarion DB185MP Car CD/ MP3 Player
Power supply to mother board connection manual for 600watt diablotek model number (psle600)
if it's a PC psu
The connectors voltage are indicated by colors
yellow is 12V
red is 5V
orange is 3.3V
black is 0V(GND)
green is PSon
purple is 5Vsb
blue is -12V
white is -5V(optional)
gray is PWRGOOD/PWROK
Nov 30, 2012 | Diablotek Computers & Internet
ATX motherboard connector pin out
Black=0V(GND)
Yellow=12V
Red=5V
Orange=3.3V
Purple=5Vsb(everytime on)
Gray is PWRGOOD or PWROK(pwr=power) must be at 5v
White=-5V(optional)
Blue=-12V
Green is PWRon must be connected to a black wire to turn on the PSU
Nov 16, 2012 | Enhance Technology ATX-1123B, Enhance...
DPS-260lp
It could be your PSU(Power Supply Unit) or your motherboard
to test your PSU use a voltmeter
1-Unplug PSU from motherboard and all unit in the PC
2-Put a small wire between black(GND) and green(PSon) wire
3-Test voltage
Orange is 3.3V
Red and purple is 5V
Gray is PWRGOOD(or PWROK) it must be at 5V
Yellow is 12V
Blue is -12V
White(optional) is -5V
Nov 11, 2012 | Computers & Internet
My computer just died the morning. I removed the
red- +5v
yellow- +12v
orange - +3.3
black- 0v
blue- -12v
white - -5v
green - ps-on(+5v)
gray- power good(+5v)
purple- stand by (+5v)
disconnect smps from motherboard give the power to smps and short green and black wires and measure the above voltages
Mar 19, 2010 | Antec SmartPower 2 SP400 400-Watt Power...
I need a wiring diagram and or a color code chart for the wires and plugs coming out of a "Power Tronic" switching power supply model SK-4145DE. 145 watt power supply. Thanks for your help.
Many power supplies have a chart on the side of the case.
Here are the wire colors for an ATX type supply:
RED +5, YELLOW +12, White -5, Blue -12, ORANGE +3.3,
PURPLE +5VSB, GREEN Power On, BLACK -Gnd (common).
Feb 14, 2010 | Power Tronic PowerTronic 145W Switching...
No activity on startup. Only fans spin up.. No video signal.
You may clean the memory board and video card connector with pencil easier and with alcohol the connectors and reinstall it. this will work. or you need to replace the power supply the orange wire 3.3v might be missing or red+5v, white-5v or the purple wire +5v
Jun 11, 2009 | EliteGroup P4M800PRO-M Motherboard
Power supplies
the purple wire.
Oct 08, 2008 | Computers & Internet
Emachines t3882 wont power on
The yellow wire carry 12 volt while the red one is 5 volt. But to check the voltage you have to unplugged all the four wires connectors (yelow, black, black red) and measure them one by one. If you say that they don't have any voltage on them then you have a faulty power supply. Replace it to solve the problem.
But if during unplugged your have the correct voltage read then it could be one of your device faulty. Normally your CD-ROM drive or floppy drive or HDD.
Mar 25, 2008 | Intel D865GVHZ Motherboard
Motherboard taken out by eMachines Bestec power supply
I have not identified the specific components on the motherboard that blow, but I can tell you the defect in the Bestec supply. The +5 VSB, which is the voltage that is on at all times, loses regulation and climbs to 8-11 volts. I believe this "higher than the required" +5V takes out the components on the motherboard involved with the computer/power supply "turn-on" circuitry. The "on" button on the eMachines front panel no longer turns the motherboard on because the "kept alive when the main power is off circuits" - which allow the on/off button to do its job of turning on the machine - no longer work.
Test your Bestec power supply by plugging it in the wall socket and have it not connected to anything. Read the voltage between the purple wire and any black wire. If you see +5.0V, then this wasn't your problem. If, like it did on mine, is closer to between 8, and 11 V, this is what took out the motherboard.
Jan 06, 2008 | Intel D845GVSR Motherboard
Compaq Evo Workstation W6000 PC Desktop Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
