Gorenje washing machine wa50140 faults Washing machine starts filling with water but then does nothing. Left on this morning to do the 40 degree cycle and must of eventually tripped electric.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check heater element
Posted on Apr 12, 2015
  • 1462 Answers
SOURCE: washer tripping the electric
fault probably with heater short to earth posswibly as a result of washing coins etc. take offr back panel and disconnect heater and tape up wires. start machine and see if trip still goes
Posted on Apr 20, 2007
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    • 44 Answers
    SOURCE: Washing machine tripping RCD
    electrical short in m/c.could be heating element. regards
    Posted on Jul 30, 2009
    SOURCE: zanussi jet stream iz16s tripping ouy rcd once filled up with
    It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
    Good luck
    Posted on May 03, 2010
    • 6277 Answers
    SOURCE: I have no manuel for
    Hi Rachel from retired Englishman in SW France,
    Methinks the answer is that you could do with a manual for your washer- for now and probably later!
    Manual
    You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
    You could also try the manufacturer's web site direct ;-0)
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C.
    Posted on Aug 01, 2011
    I have just moved into an Apartment with a Gorenje wi 62112 Washing machine, I have no manual Can anyone tell me what the numbers on the Dial mean What should I choose for a general wash.
    Gorenje has some documentation for their washers here: http://www.gorenje.com/simplicity/en/washing_machines/simple_manual_for_washing . The numbers indicate the water temperature (in Celsius) for a given cycle. The common choices are a cottons load in hot water (60 degrees). This is great for towels and other whites. The mixed load is for permanent press that can be in warm water (40 degrees). Then there is a cold water cycle for delicates (30 degrees). However, you should check the fabric care label before choosing the cycle.
    I hope this helps.
    Apr 20, 2016 | General Washing Machines
    Fisher and Paykel Washing Machine model mw512
    this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
    when it's filling with water, does the bowl go around slowly?
    Sep 11, 2013 | Fisher and Paykel Washing Machines
    Gorenje wa72145bk erro f2
    it your door lock that faulty
    Jul 01, 2012 | Washing Machines
    I have no manuel for my Gorenje WA50140 washing machine and need to know what each Wash Cycle Programme is
    Manual
    John C.
    Aug 01, 2011 | Washing Machines
    Spin cycle is the only that works
    Check for water supply for proper fill. Then other timer circuits.If wter gets filled, fault may be with the water level sensor/wire.
    Mar 28, 2010 | KitchenAid KAWS750L Top Load Washer
    No manual for Gorenje front loading washer.
    Here is a link to the Gorenje website, you can download the manuals from there which explain all the symbols. This link is for the WA50140 machine which I have, just click on the 'manuals' tab
    http://www.gorenje.co.uk/laundry/washing_machines?c=161105
    Jan 27, 2009 | Washing Machines
    Hi, My washing machine is not completing the washing cycle, it gets stuck when the water should go out of the tank. There is anormal noise like if something does not have the strengh to pull the water...
    well Xavier, looks like you have a bad water pump in your machine, or its clogged up with debrie, either way you will have to have a qualified tech check it out unless you are extreamly handy with replacing pump motors, its not to easy to do, hope that helped ya
    Jan 19, 2009 | Refrigerators
    Fill with water, stop then no agitation. Please help
    ck left hinge screws lid switch is under left rear and is tough to acess if switch seems suspect 2 screws in rear of console are removed and console rolled back to acess switch also ckd wires to motor have seem problem with poor contact in motor connector
    Apr 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    55 people viewed this question
    Top Washing Machines Experts
