Question about Brother Sewing Machines
My se-400 brother embroidery machine keeps desplaying check and retread upper thread.
    Master:
  • Brother Master
  • 470 Answers
If you can see that the tread is there and in the correct place, the Thread Out sensor may not be working right.
Our solution with several Hus Rose machines was to disconnect the Thread Out sensor.
Posted on Apr 08, 2015
SOURCE: Brother Sewing & Embroidery SE-2700
How do you retime a machine? My machine will miss stitches ot completely break the thread. The top thread misses a lot of stitches.
Posted on Mar 28, 2008
akylas
  • 26 Answers
SOURCE: brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Posted on Jun 10, 2008
SOURCE: Brother PR600 embroidery machine has
Just got the pr600 machine. Can't get the upper and lower thread to connect. Keep getting the error message to check upper and lower thread.
Posted on Sep 01, 2008
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
  • 55 Answers
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
Brother 780D will not feed thread through machine.
It is very important to have the bobbin case and the top tension both right. If the thread is getting stuck there is a problem. Always thread the top with the foot up. While threading make small pulls to make sure there isn't any places getting jammed. I've attached a rule document to help you to adjust the tension of the top and bottom.
May 20, 2015 | Brother PE-770 Embroidery Machine
My sewing machine brother SE-400 does not work the LCD display say the security device is activated. How I do to unlock
remove the embroidery unit and check the bobbin case. Usually, there is some thread tangled down there.
Aug 14, 2014 | Sewing Machines
Do feed dogs drop automatically on SE-400 when embroidery unit is attached?
Yes they should unless the tab on the middle of the embroidery unit is broken.
Jul 31, 2014 | Brother SE-400 Sewing & Embroidery Machine
Error Code: Check and rethread the upper thread
Yes. It is a sensor on the take up spring. If you miss threading the take up spring you get this error. If take up spring is bent or broken you get this error or if sensor is damaged this error occurs.
May 16, 2014 | Brother LB6770 PRW Computerized Sewing...
My Brother SE270D keeps jamming up and getting thread all tangled up The feed is not advancing either.
Make sure you are using 60 weight bobbin thread only in the bobbin, also make sure you are using only SA156 ( SFB-XA5539-151) bobbins, the size 156A are not for this machine. I have used Singer size 15J bobbins with no problem. The bobbin should have slightly rounded ends, not flat like a regular bobbin. This helps the thread over the bobbin at high speeds.
I threw my machine out of time the first three times I used it for embroidery and decorative stitches. Had I read the manual, I'd have known to use 60 wt bobbin thread. I have also used 90 wt with no problems...60 wt is what comes with the machine.
If you have to take the machine in for service, make sure to take sample of the problem and the embroidery unit, thread you used, etc. Take it all and tell them to test it all.
My Brother dealer felt these Disney machines were great little workers..and said they are not hard to repair...some dealers don't know enough about how to repair the thread cartridge, so tell you the machine is not worth repairing. It is...I've had mine for 4 years.
Hope this helps some. You may have to take the machine in to be timed / cleaned...once that's done and you are using proper thread and bobbins (upper thread - you can use any, bobbin it's 60wt)...you will love your machine.
Apr 14, 2010 | Brother SE-270D Computerized Sewing...
Stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Dec 10, 2009 | Brother SE-270D Computerized Sewing...
Thread wad on undersurface
machine not threaded properly? wadding thread underside means upper thread does not have tension.
Jun 30, 2009 | Brother SE-270D Computerized Sewing...
My brother PE-400 sewing quit sewing
i had the same problem and realized i was using the wrong kind of bobbin. there are specific ones for an embroidery machine and specific ones for a reg. sewing machine. hope this helps
Jan 31, 2009 | Brother PE-150V Computerized Sewing...
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
Sep 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother PE-150V bobbin thread
Apr 30, 2008 | Brother PE-150V Computerized Sewing...
Sewing Machines Logo
78 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
