Question about CIPHERLAB 8000 Series Handheld Mobile Computer
MY CIPHER SCANNER WILL NOT DOWNLOAD THROUGH THE TELEPHONE
Always Says When Barcode Scan data too long
how you can fix this is . in the forgeAG program click on open icon then insert the CD that came with the scanner then search under the cd cpt_tools then application generator then batch then 8 series then AG samples and choose the 8000 one uploaded it to the scanner . and you will be good to go
Jul 12, 2011 | Cipher LAB MODEL 8000 POCKET SIZE MOBILE...
I have a Cipherlab scanner 8001, when i connect it to a linux computer, it doesnt download it gives me a Time out error, but when i connect a Cipher scanner 711 to the same COM port it works. Please advice...
OK,you indicated COM1 serial port is working on the a Cipher scanner 711.
Please check the communication setting on the Cipher scanner 711.
The most popular setting are
AUTO BAUD RATE
or
9600 bps 8 bits N for no parity check and 1 for check bit.
Short for as
9600 8 N 1
Check the setting on the Cipher scanner 711 communication speed and make set the Cipherlab scanner 8001 to the same rate.
MAKE SURE YOU RE-BOOT the Cipherlab scanner 8001 before re-try.
Please keep me up to date on the fix via email.
Jan 30, 2011 | CIPHERLAB 8000 Series Handheld Mobile...
Casio TE2200 Cipher 1000 CCD RS232 scanner still not working
Jeff I feel your pain. I have never use a Cipher scanner, I stick with the well known brands like metrologic. I see them for about 385 each. I know you can get one for less used or online. When I set up the scanner I usually use the booklet and scan the codes into the scanner itself. Take 20 seconds or less. You probably did that but just checking. My answer is at this point and since its not in my shop, is, Metologic. Your casio's com2 is where the scanner should be and 298 should be 12000. I understand you can get it to work with hyperterminal but, that in essence means that the scanner works but not necessarily with the settings. These kind of issues are 99% of the time in the settings. The list I sent on the last message was the barcodes used to program the scanner. you know expand ean13 etc. that is where i still feel it lies.
Im doing my best I may have to set up my own scanner on my 2400 and see how it works.
Chris
Sep 24, 2009 | Casio Parts Cash Register PC Desktop
Casio TE2200 with Cipher 1000 Barcode scanner still not working
I have set up the casio 7000 to use a metrologic orbit scanner. The scanner program is most important. I don't know what Cipher uses, but I think that is where your problem is. I will do some more research and get back to you.
The 9789745002500 is correct you will use a 13 digit number
Sep 23, 2009 | Casio Parts Cash Register PC Desktop
How do I turn off the beep it makes when it finishes scanning?
I donno how to control through software, but by removing the buzzer, you can cut the sound!
Scanners give a beep and they have been designed to communicate even when the operator is not around. Beeps are different for different conditions, from paper Jam to Error to Job finished. Quite an effort goes in designing the beeps, be it microwave or washing machine or Telephone handset. Lets respect the design effort and leave it as it is.
S. Mohan
Jun 05, 2009 | Panasonic KV-S3065CL Path-Through Scanner
Zebra QL 420+ wireless printer works only without cipher/TKIP
Hi
With Label Vista
  • Go to Printer Tab
  • Define the com Port settings (use serial or usb)
  • Go to Printer settings
in network tab :
  • Put your network configuration ( IP address or DHCP,submask, gateway; ESSID, port number .....)
In 802.1X WPA
  • Select WPA WPA2
  • Authentification PSK
  • Put the username and password in EAP section
Mar 16, 2009 | Zebra QL 420 Plus Thermal Label Printer
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
PRINTER/SCANNER INSTALLION
The telephone jack/cord is only needed for utilizing the "FAX" funcions. For printer/scanner setup see http://www.lexmark.com/publications/eng/x6100/index.html
MM85
Jul 26, 2008 | Lexmark X6100 Flatbed Scanner
IE 7.0 Change it into High Encryption.
u can change the cipher strength by edit the properites of the IE7.0
or change in "services" which is in control panel -> Administrative Tools
Mar 13, 2008 | Microsoft Office Outlook 2003 for PC
Can you help me download my scanner
Try here: http://www.umax.de/WebNew/index.htm In my experience, the German site offers more drivers.
Apr 13, 2007 | Umax Astra 610P Flatbed Scanner
CIPHERLAB 8000 Series Handheld Mobile Computer Logo
413 people viewed this question
Top CIPHERLAB Computers & Internet Experts
David Payne
David Payne
Are you a CIPHERLAB Computer and Internet Expert? Answer questions, earn points and help others
