Question about Kenwood KAC 5206 2 Channel Performance Amplifier
When I turn on my deck the amp turns on but as soon as sound turns on the amp shuts off any ideas why
I have a pioneer deck works awesome
2 Suggested Answers
SOURCE: My kenwood kfcw3011 stopped working. Amp indicator still on.
had the same problem and for me it was because i needed a four channel amp instead of the 2 channel amp that i was running. to much speaker for my 2 channel amp
Posted on Dec 15, 2009
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
New pioneer FH-X820BS tiny to no sound
Most car audio is designed to push 4 ohm speakers not 8. Any chance the stock radio was attached to an amp that is not powering up with the new deck. Usually you will have a remote turn on wire that signals any amps to fire up when the deck does.
Jul 04, 2016 | Pioneer Audio Players & Recorders
Pioneer DEH-X6500BT amp & speaker problems
Depending on the car and your setup sounds like the amplifier is not wired properly or an issue with adjustments on your deck itself. More info on your sound setup would be helpful.
Dec 28, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
I keep getting ERROR 19 when I try hooking up my iPhone 3GS to Pioneer DEH-3200UB car stereo. Followed instructions in manual without any luck. Tried looking at Pioneer webite for an explanation and a...
Did you recently update your iPhone 3GS firmware to iOS 4.x ? There is a signficant number of people with this problem after the firmware update. Here are two possible solutions that have worked for some people.
1) Turn off your iPhone (hold the power switch down,then swipie off). Turn the deck on to your USB1 or USB2 (whatever you are using). Now plug the iPhone into the deck. This should turn the iPhone on, and "reset" the connection to the USB.
2) Turn the deck on and switch to the proper USB source. Connect the iPhone to the deck, then initiate a "hard reset" of the iPhone (hold the power
Sep 04, 2010 | Pioneer Car Audio & Video
Pioneer deh p3100ub shuts off when i touch deck
sounds like the faceplate is not seated right or has dirty connections but it is in your detachable face plate. your still under warenty.
May 24, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
No rear output
yea your ic in the deck is going so i suggest you buy one which is cheaper than buying a new deck
Sep 15, 2008 | Pioneer DEH-P5800MP CD Player
I cant get my subwoofer system to work
Do you use a amplifier to power the subs? If so, the amp needs a signal to turn on. This is supplied by the blue/white wire labeled 'system remote' in pioneer radio's.
Search for the next term on this site for more information about this wire:
Remote turn-on in car amplifiers is obligatory?
Sep 13, 2008 | Pioneer DEH-P4100
Remote wire
easy way to find out ..test light .one end into blue wire .other end onto earth turn deck on .if lights up yes ..just check that if you insert a disc or anything it does not shut down ..if it does it will not turn your amp on when play discs
Jan 22, 2008 | Pioneer DEH-P3500 CD Player
Amp problems
did you run your 12+ to the battery? did you supply a sufficient ground of least 2x the size of the power lead?..did you hook up to the amp turn on lead and NOT the power antenna? model numbers of radio and amp would really be helpful...my email is troublerst@hotmail.com send me specifics and we will work it out
Nov 07, 2007 | Car Audio & Video
My amp keeps going into protective mode.
try to lower the SLA option on ur deck maybe the amp is pulling to much current from the battery try putting a battery with more AMPS
Jan 06, 2006 | Jensen LXA400 Car Audio Amplifier
Kenwood KAC 5206 2 Channel Performance Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
