Question about Moshi Voice Controlled Talking Alarm Clock
How do I take clear cover on base of Moshi talking alarm clock off in order to dry it when liquid has been spilled?
Coffee spilled on it.
How to clean liquid under round grate oven base?
tip it toward the back and be prepared to wipe up a big mess
Apr 12, 2015 | GE Advantium 120 Convection/Microwave Oven
Tip
Spilled liquid on Keyboard!
1. Purchase plastic keyboard cover. 2. Keep coffee etc. anywhere not near keyboard.
For spill, unplug keyboard. If non sugar liquid, invert keyboard, shake or tap gently. Wipe with lent free absorbent cloth while still inverted. If soda or coffee with sugar, pour 1/4 cup of clear clean (distilled the best) water onto keyboard (yes), Then invert. Let dry a minimum of several hours still inverted. I cheat with a hairdryer on low 6-12 inches. After keyboard is completely dry (and cool). Plug in after turning computer off, restart, test all keys, including shift, option etc. If keys miss or don't work buy new keyboard and cover! Aloha, Cliff
on Sep 27, 2014 | Apple 24" iMac Desktop
Tip
Liquid spills
Todays notebooks & laptops come equipped with spill resistant keyboards. Thats a big help in itself. But some are not . If your notebook has suffered a liquid spill while its on , IMMEDIATELY shut it down. GET AWAY from carpeting or metal furniture or objects: stand on wood or cement floor only. Turn the unit and place on its side to drain it from the liquid (NOT UPSIDE DOWN) and to avoid further damage to mainboard and keyboard. DO NOT TURN IT ON AGAIN  . Remove the battery, hard disk drive, CDROM, memory modules, remove back cover, until exposed to mainboard. Take conventional hair dryer, blow dry using HIGH heat, slowly move over peripherals and mainboard  five inches away with  Extra drying process on keyboard and mainboard. Using a few cotton balls, pat down any excess liquid by absorbing into cotton -- blow dry this area intensley for long time (20-35 minutes, depending on amount of liquid spill). Wait a few days , replace all parts and turn on notebook.
on Jan 21, 2012 | HP Computers & Internet
My laptop is only a month and a half old. It got accidentally wet and it is turning on but the screen does not come on. It is an Acer Aspire 5250. I believe the computer is aired out and dry now.
In most cases, the problem is going to require significant dis-assembly to dry out the computer and get it working again. Depending on the liquid involved the damage can be minimal or severe! If it was just water with nothing else in it, then getting it dried out within a few hours will likely have no affect on it, provided of course it did not sustain damage from being shorted out. unplugging it and removing the battery IMMEDIATELY is the best choice to prevent significant damage. Since the liquid can get into areas that simply are not going to dry out until evaporation occurs, it is best to not delay and remove as many access covers as possible and try blow drying it. if the water got into the screen, this is not going to work and the screen will have to be dismantled.
If the liquid involved ANYTHING other than water (soda, coffee, sugary, etc) the damage that can result from continued exposure to these substances WILL do permanent damage if not removed within a few hours of the initial spill.
You will be surprised how many little spaces that water will go that simply will not dry out until exposed.
The last laptop I worked on had coffee spilled on the keyboard. The entire main board, processor and several tiny socket connections were saturated and letting it air dry would not have helped.
I suggest taking it to a professional for service and repair. I also recommend ANYONE buying a laptop, get damage warranty coverage just for reasons like this, its definitely well worth the price.
You can expect the repair on this to be easily more than the cost of the damage warranty.
Jul 19, 2011 | Acer Computers & Internet
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
Some coffe got down in the base of my magic bullet. What do I do?
For a Step-by-Step instructional PDF on how to disassemble, clean and reassemble your Magic Bullet send an email request to: Tinker@TinkersWorkshop.com.
Jan 01, 2010 | As Seen On TV Magic Bullet Food Processor
Liquid spilled into the cooktop (gas with electrice ignition) and now the igniter doesn't work.
If it was clear liquid, after a day or so your cooktop igniters should start working again. If it was a gooey spill you may need to gently clean them. They will not work until they are very dry.
Nov 30, 2009 | Kitchen Ranges
Coffee spilled on adding machine
The sugar is the problem, To solve it you must disassemble the keyboard wast it out with hot water let everything dry then reassemble. an awful lot of work for a inexpensive calc.
DickyO
Sep 21, 2009 | Sharp EL-1801P Calculator
Touchpad on dell vostro wont work
Sounds like a short to me...you probably missed some liquid as it does not take much...go thru the process again. I know thats not what you wanted to hear...but liquid on those things is a nightmare and you just never know where some of it went. A complete drying is in order...if it was a sticky liquid like soda....even when "dry" it can still short it out. If it was water...double check you got all the water...then let it sit out for a day.
Apr 24, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
HTR-5830
The liquid has shorted out probably every electronic component in the unit. It is fried. You need a new one.
Mar 27, 2008 | Yamaha HTR-5830 Receiver
Moshi Voice Controlled Talking Alarm Clock Logo
Top Moshi Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Moshi Audio Player and Recorder Expert? Answer questions, earn points and help others
