Question about Vizio VX42L 42 in. LCD TV
Vizio logo does not light up amber when plugged in but turns white when power button is pressed. no picture or sound. Big Transformer on power board makes a light buz sound when plugged in also.
  • Kennith
    Kennith Apr 14, 2015
    Thanks for the help, both inverter boards were shorted.
    Sergeant:
  • Vizio Expert
  • 264 Answers
1. When the TV powered up, please measure the 24V, 12V & 5V are there, if one voltage is missing, you may have a defective power supply.
2. If the power supply lost the 24V source, you may unplug the power supply connector on both the inverter board, then power it up, if you got the 24V back, you do have a defective inverter board, you may unplug them one at a time to locate the bad one.
3. If the power supply & inverters are good, you may have a defective main board. The common problem on the main board is that a voltage regulator is bad, you may use your millimeter to measure them 1 x 1. The out put voltage (on the heat sync) should be 1.25V + the control voltage (Pin 1), for example: if the control pin voltage is 0, the output voltage should be 1.25V, if the control voltage is 2.05V, the output voltage should be 3.3V, if one of them is out of range, replace it, you may find the part from Digikey Co. The part number printed on the regulator is AMC1117.
Posted on Apr 08, 2015
Testimonial: "Thanks both inverter board were shorted. Waiting on parts."
SOURCE: No Sound, No Picture
I had the same issue on my Vizio and fortunately it was still covered by the Costco extended warranty from where I purchased my tv. The service tech came out yesterday with a power supply and main board which is what I understand is usually the issue with your and my symptoms. He replaced both boards although he felt the issue was in the main board 3647-0072-0150 and not the power supply. Tv is working just fine now and actually may be even a little clearer after the board switch. I understand you can purchase the boards and from what I've seen the tech do, it is no more difficult to replace than if you were building a computer if you are comfortable with that. The most time consuming part of the repair was removing and replacing the screws.
Posted on May 17, 2009
  • 92 Answers
SOURCE: Power Light comes on but no picture or sound.
for your VP50, it could just be simple as a power supply but it could also means more. Do you have the amber LED light when off and green when on? if so, try the main board first. If that doesn't resolve the problem, then change the sustainer boards.
Posted on May 30, 2009
  • 27 Answers
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Posted on Apr 09, 2010
Testimonial: "alteans is very helpful."
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
freetek
  • 5568 Answers
SOURCE: My vizio e420vl turned itself
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
Posted on May 29, 2011
How do I repair my Vizio VP422HDTV10A?
What have you done to address the issue? Confirm that power is reaching the PS? if there have you replaced the PS or made repairs to it?
Unless you make specific inquiries you make it difficult if next to impossible for anyone to help you. Keep it up and all you will have is a big, wide paper weight.
Mar 12, 2016 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
How do I fix my lcd tv that won't turn on? It does not appear to be the powerboard.
Vizio logo is an indicator that the tv is live n changes to white that the screen is on meaning if no change to white the smps switch mode power supply board ain't switching the mother board....diagnosis is its MOSFET transistors need replacement or the smps board n ya tv will be fine
Sep 22, 2015 | Vizio XVT473SV 47 in. LCD HDTV
How to fix my vizio tv that has power but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 09, 2015 | Vizio Televison & Video
What is voltage supposed to be for P on pin on power supply?
The power on is usually 3.3vdc, but on some sets it's at 0v to turn on the set, and 5v when the set is off. Your power supply maybe ground activated. If you replaced the main board, then the power supply is your problem
Jun 08, 2013 | Vizio VP422 42 in. Plasma TV
Vizio VO47L FHDTV10A wont turn on, logo goes from amber to white, tv clicks once and wont turn on. remote will try to turn the tv on. suggestions?
check your inverter board and wires 2 make shure there not arking. then check your six transformers on your inverter with volt meter
Jan 31, 2013 | Televison & Video
Vizeo-e420vo wont come on
If the vizio logo turns amber as soon as the power cord is plugged in you can assusme the poser supply is good. If the logo doesnt turn white when the power is pressed then its the main board. You can get the replacement main or power board from www.tvcircuitboards.com
Jan 09, 2013 | Televison & Video
I have a 32inch vizio tv that has no orange light on the logo but when turned on there is a white light and no picture or sound can any one help
The power supply board has some issues with its stand by supplies which should turn the logo orange as soon as its plugged in if the logo doesnt turn orange replace the power supply board You can get the power supply board from www.tvrepairworld.com
Dec 13, 2012 | Televison & Video
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Vizio VX42L 42 in. LCD TV Logo
141 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
