Question about Car Audio & Video
Is the memory of presetstations and audio set powered by the car battery or by an build in battery inside the radio a deh 1700r
5 Suggested Answers
natenash7986
  • 53 Answers
SOURCE: Pioneer DEH-1700R - Storing Radio Stations permanently
your constant power wire is not hooked up or it has come loose that is why nothing will stay saved on the unit have it looked at and see if they wont fix your problem cheap...... its a easy fix
Posted on Sep 24, 2008
  • 82 Answers
SOURCE: preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Posted on Apr 17, 2009
SOURCE: Pioneer DEH-P590IB car radio has power and will not turn on.
Want to sell your faceplate for that deck?
Posted on Sep 18, 2009
bunnydawg
  • 5158 Answers
SOURCE: set a pioneer 2950 deh-2950
if that radio is of the anti theft variety you will need the code to get it working. if the radio is completely dead i suggest first to recheck the cigarette lighter fuse (that is frequently) the circuit the radio is on. interupting the power would be a good way to reset the radio. quickest way is to just unhook the battery for about a half hour or so.
Posted on Mar 03, 2011
I have a pioneer DEH 150 radio it's loses its memory when the isolator switch is turned off in the tractor?
The radio has been wired incorrectly so no 12v battery power is applied to retain memory when the isolator switch is turned off.
Jan 02, 2017 | Pioneer Car Audio & Video
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
My radio memory cant remember the channels after i have turn off the car power
The yellow wire from the stereo should be connected to a constant 12volt power source (battery). This controls memory for the stereo.
Apr 04, 2011 | Pioneer DEH-1900MP CD Player
Pioneer DEH-1500. Battery was disconnecred for an extended time. How do resey the radio.
ok when you pull the radio from the dash you should be able to locate a constant power source to the radio. This is for the radios memory , like when you have presets for radio stations. when you unplug the stereo from the harness all memory will be lost and it should reset. Hope this helps ;)
Jan 01, 2011 | Pioneer DEH-1500 CD Player
The radio will not hold memory
If your radio will not hold memory then you are lacking a constant 12 volt power source. Check the yellow and red wires at the radio. The yellow wire should be connected to a constant 12 volt power source (battery) and the red wire should be connected to a switch 12 volt power source (accessory or ignition).
Nov 23, 2010 | Pioneer DEH-2800MP CD Player
My car battery died, after giving the car a jump, the car started, but now my pioneer DEH-P2900MP car stereo won't work at all. could you please assist. thanks.
If you have already checked the fuse(s) that supply the radio and none are blown, you may want to try to reset the unit by disconnecting the power feed to it. Keep in mind that the radio likely has two power feeds...one for the ignition and another that keeps all memory functions up and running, even when the ignition is off. Disconnecting both of these may allow the radio to reset.
Feb 11, 2010 | Pioneer DEH-P2900MP CD Receiver...
The radio won't keep the memory settings of the chanels.. How do I get it to keep them ?
Most radios have a yellow memory wire,(sometimes it is red) This wire needs to be connected to a constant power source, i.e. battery, cigarette lighter. It needs to be connected to something that when the vehicle is turned off, it still has power.
Nov 22, 2009 | Pioneer DEH-2100 CD Player
Preset memory not working on pioneer DEH 1700 radio
Apr 06, 2009 | Pioneer DEH-1700 CD Player
Sep 16, 2008 | Pioneer DEH-1700 CD Player
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
