Question about Samsung TV Remote Control
Direct tv remote control - tv volume
Posted by christi04 on Nov 09, 2007 Report abuse
I'd like to program my new Direct T.V. Remote to my new Samsung TV, to make the volume "SLIDE" up & down instead of manually pushing the "up button over & over & over.....to turn the volume up. How can I do this???
Still need a solution for this problem?
T
    New Friend:
With DTV remotes, there is no way to program it to "slide up" interface within the tv controls how the volume will increase, however, Samsung is a very friendly brand with directv all you need to do is slide the mode switch at the top of your remote to tv (all the way to the right), next you will hold down the mute and select (small button beneath the volume key) and the select (big orange-yellow button in the center of the remote) down together, it may take 5-10 seconds but you will see the green light at the top of the remote flash twice rapidly (light should blink when initially pressing buttons, this does not indicate a readiness for correct code), after that you will want to enter the codes for your brand, some models of reciever and remote can automatically scan if you use the in reciever menus.
http://www.directv.com/DTVAPP/global/functionalPageIF.jsp?assetId=cms_remote_codes#h:620.14 (remote control code look up tool from directv.com)
http://support.directv.com/app/answers/detail/a_id/1785 (Steps for accessing programming remotes through reciever menus)
Posted on Apr 24, 2013
I have the same problem!
Posted on Jan 25, 2008
Direct tv remote programming to operate tv
call directv. they are very helpful with programming remotes.
1-800-247-3288
Mar 07, 2014 | Samsung Televison & Video
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
I just installed direct tv and their remote wont let me change volume. if I use the tv remote I lose the programming. Need a code so the tv can be controlled by direct tv's remote.
Hi, post the direct TV remote # and the box model # so I can lookup the info for you. you probably already know directTVs remote programming is built into the menu (codes and all).
You did not mention if the DT remote powers the TV on or off?
post more info if you still need help and I'll try
Thanks
Eric
Sep 04, 2009 | Proscan 42LA45H 42 in. LCD TV
Direct TV remote quits working - conflict with Samsung LCD?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Sep 03, 2009 | Samsung TV Remote Control
Directv remote increases volume slowly
The Direct TV remote has to be programmed properly. See the user manual for the process. The problem is, the user manual tells you to enter a code for the TV, but gives you a long list of codes that may work. So it's simply a problem of trial and error. For me, the first code in the list gave me the same results that you got (having to press volume repeatedly). But when I programmed the 2nd code in the list, pressing and holding the volume worked!.
I can't guarantee it, but I suspect you'll have the same result.
Feb 13, 2009 | Samsung TV Remote Control
Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Jan 04, 2009 | Televison & Video
Direct tv remote- volume control
You are wanting to make a digital volume control function like an analog one. Can't be done.
Apr 25, 2017 | Universal Remote Control DIRECTV Universal...
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Feb 17, 2008 | Universal Remote Control DIRECTV Universal...
Need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Oct 01, 2007 | One For All URC-3021 Remote Control
Samsung TV Remote Control Logo
361 people viewed this question
Jerry Greenberg
Jerry Greenberg
