Question about Roper Refrigerators
ROPER REFRIGERATOR WILL QUIT WORKING. I UNPLUG IT FOR A COUPLE DAYS AND WHEN I PLUG IT BACK IN IT WORKS FOR A COUPLE WEEKS. THEN IT QUITS AGAIN. WHAT WOULD CAUSE THIS?
  • Roper Master
  • 5,323 Answers
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts.
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Posted on Apr 08, 2015
GE GSL25JFTABS freezer quits then frig quits cooling
Probably your auto defrost element(s) is (are) burned out.
Aug 13, 2014 | Refrigerators
Just stopped freezing....so i unplugged it...then plugged it back up and it ran for about a week....then done the same thing- quit working...so i unplugged it again....then plugged it up again and it...
Did you remove the cover in the back of the freezer section?, see if the fan motor is turning, if the fan is not turning you will need to replace it and this will correct the problem allowing the air to circulate.
Nov 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Sounds like the defrost timer is not working. When you unplug it it will defrost and then as it runs it frosts up again till it stops the air flow and ....
Either buy a new defrost control and install it or have a new one installed by a tech.
Nov 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge stops running after about a day.
That is a faulty defrost system.
Test the defrost thermostat, heating coil and fan, and replace the faulty part.
the defrost system is located behind freezer firewall.
Regards.
Sep 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator and freezer quit working.
That sounds like it could be the problem. The common causes are a bad defrost heater, defrost timer or a defrost thermostat.
Aug 27, 2009 | Belling BE811 Bottom Freezer Refrigerator
Refrigerator/freezer just quit. Lights are still on
What has quit? The cooling of the refrigerator or the ice maker/ dispenser?
Jun 16, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
It just quit after a couple of months of very little use.
Most likely you have a defrost problem. When you unplug it for a couple of days, it thaws out and you plug it back in and it works until it freezes up again. Possible problem ...1 of 3...defrost timer...2 of 3...defrost heater...3 of 3...defrost bi-metal.
Apr 01, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Aug 27, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Refrigerators Logo
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
