SOURCE: Frigidaire PLMV169cd Microwave Exaust Fan Hums but wont run
Do you mean the hood vent fan? (That would be a large assembly a little smnaller than a loaf of bread, I guess)
If it's this one, I would suggest you check the big starting capacitor on the circuit board and the connections on that cap.
Or do you mean the cooling fan inside, which would be small enough to basically fit in your hand?
In either case, I would measure the line voltage to be sure it's in the 110-125VAC range.
If it's grossly outside this range, you may have a problem with other electronics or light bulbs bblowing or being dim or erratic.
One handy thing about Whirlpools is that behind the control panel they have a mini-manual which is very useful in troubleshooting.
It may be that you have some toruble on your control board, which we repair for customers nationwide.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: remove a door on a microwave
I wouldn't remove the door myself if I were you. If you just got the microwave, it should be under a return/replace policy, or a warranty. I would recommend returning the microwave and getting a sturdier one, as you don't know if the problem exists for all microwaves in that series, and most stores don't allow the replacement to be return/replaced.
SOURCE: exaust fan has weak suction on maytage mmv4205baw
This is due to poor air flow, either to a blockage or a problem with the internal cooling fan or hood vent exhaust fan.
Are the grease filters or charcoal filter clogged?
You may want to check your owner's manual for info on checking the filters. Grease filters can be cleaned, but charcoal filters must be replaced about every 6-12 months.
The installation manual will tel you if there's some error in the installation setup.
You can download Maytag
owner's manuals and installation instructions here.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: exaust vent/ fan very weak
In your duplicate post, you mentioned your model, so here you go:
We're
