Question about Sewing Machines
I have a Brother PC3000 and I cannot get it to change stitches. Defaults to 01 and will not respond to any pressing of the buttons.
    Master:
  • Sewing Machines Master
  • 470 Answers
Pdf copy of Manual is below:
http://www.manualslib.com/manual/441597/Brother-Pc-3000.html
You may want to call Brother Support:
Support Center
Posted on Apr 08, 2015
How to change the thread spool pin on babylock model esp
Depends. Some spool pins simply push in and snap in place, but as many machine brands existing, there are probably double the different spool pins available...
http://www.sewingpartsonline.com/babylock-esp-sewing-machine-parts.aspx If you order from one of the online vendors, they will probably be able to advise how to install it.
Spool Pin for Brother Baby Lock X59053051 Old X59053022 X59053052
SPOOL PIN Babylock ESL ESP Espire Brother CS8072 PC2800 PC3000 PC6500...
Mar 24, 2017 | Sewing Machines
I have a Singer Curvy 8780. All I want to do is sew a straight stitch. What are the settings?
You'll need stitch pattern 01 in the first group after you press the utility stitch button (top button on the left of the 4 way arrow keys). Press button A (the left most up-arrow below the LCD screen). Use buttons B (move left) & C (move right) to select the needle position and D (shorter) & E (longer) to adjust the stitch length. E is the right-hand button in the group. Start with the tension set to Auto and adjust as needed based on your fabric and thread. For normal straight seams, start with the default settings.
Singer has the manual for the Curvy 8780 on the product site: http://www.singerco.com/products/1545/8780-curvy#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/089a99d1802347d9441d83e8a591e6d0db17b80c.pdf . See page 30 for the stitch pattern; page 40 starts a longer discussion of straight stitching.
I hope this helps.
May 25, 2016 | Singer Sewing Machines
I get an E2 error on my Brother CP7500 and the button lever is all the way up
A stitch other than the buttonhole or bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Raise the buttonhole lever before continuing the operation.
Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operation
    One beep is sounded.
  • If an incorrect operation is performed
    Two or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangled
    The sewing machine continues to beep for four seconds.
    The machine automatically stops.
    Be sure to check for the cause of the error, and correct it before continuing to sew.
reference: http://support.brother.com/g/b/faqend.aspx?c=us_ot&lang=en&prod=hf_es2000teus&faqid=faqh00000059_000
user guide:
http://download.brother.com/welcome/doch000470/bc21es20cs60ce50ex66xr6677ug10en.pdf
quick reference guide:
http://download.brother.com/welcome/doch000566/bc21es20ce50qg02enfresdeitnlru.pdf
Dec 15, 2014 | Brother CP7500 Sewing Machine
Cannot get the sewing machine to sew along. It wants to stay in one place. Have machine threaded correctly, Set on 01 and I believe the stitch length is set at 5.0. But the space below the stitch length...
I would study my manual if I were you, pages 27 and 35 explain your settings pretty clearly. If, you don't have your manual handy, go to www.brother-usa.com and under support and home sewing and embroidery download a free copy of it. You can also call Brother customer service at 1-877-276-8437 and ask them if your machine still gives you grief.
Jan 02, 2011 | Brother CS-100-T Computerized Sewing...
Machine shows 2 E whaat can I do to fix it
Have you got a manual?
If not one is available free to download from the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000_ES_2000_EN_185.PDF
Look on page 64 of the PDF file for the error codes.
E2 means:
Problem: A stitch other than the buttonhole or bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Solution: Raise the buttonhole lever
Hope this helps!
Sep 24, 2010 | Brother CS-6000
The machine was accidentally dropped. We started with an E7 error, and now an E3 error message.
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed
E3 means
The buttonhole or bar tack stitch was selected and the
start/stop button was pressed while the buttonhole lever
is raised.
(make sure buttonhole lever is in correct position)
If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears.
download manual for this model at
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_cs80eus&dlid=&flang=English&type2=-1
Hope this helps
Feb 05, 2010 | Brother CS-80
How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
126 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
