ON MY PHILLIPS FLAT SCREEN MODEL 42PF7320/28 I GET NO SOUND OR PIC ON THE TV MODE.I DO ON THE HDMI WITH A ROKU BOX, THE MENU DOESN'T HAVE AN OPTION TO RESET THE TV TO FACTORY SOMEHOW. ANY IDEAS.
SOURCE: akai lct42z6tm
I can confirm that replacing these 4 capacitors worked perfectly. I work in construction so i am not a technician or anything. I did not even have a solder iron. I have photos of the board if anyone would like to see them. Took me about a hour to replace the 4. I had to use (2)35volt & (2)50volt cause radio shack only had 2 of each and it works like a charm. This TV has been in storage for 6 months until i found this article on the problem. Cant say thanks enough!!!!!!!!!!
Posted on Jul 14, 2008
mistersony
  • 320 Answers
SOURCE: Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Posted on Oct 19, 2008
dsacco86
  • 1077 Answers
SOURCE: My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
Posted on May 27, 2009
SOURCE: trying to hook my roku box to my sharp aquos 46 in using my hdmi
according to roku support hdmi won't work with the aquos as of today (1/6/2010). i have no idea if it's an hdcp issue or not
Posted on Jan 07, 2010
SOURCE: No picture on Westinghouse flat screen tv
westing house flat screen tv hd...has sound no picture
Posted on Jan 15, 2011
I GET NO PIC OR SOUND ON THE TV MODE, I DO IN THE HDMI WITH A ROKU BOX. I CAN'T SEEM TO FIND THE SETTING OPTION ON THE MENU TO RESET THE UNIT.
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Apr 08, 2015 | Televison & Video
How do i connect my wireless Internet router to my proscan Smart TV
Go into settings on your tv & activate the wireless mode
Feb 11, 2015 | Computers & Internet
How to connect Roku 3 or do I need Roku 2?
I think it will only work if connected directly to the tv with the correct cable.
Dec 27, 2014 | Pioneer Televison & Video
I have a Phillips plasma tv model number 42PF5521D/10 serial number VN4B0708013071 i was watching it on 1 of the 2 hdmi channels when all of a sudden it just went off when I turned it back on all I had was...
Does it work on the cable/antenna input jack? Can you get the menu screen to show up? If none of the inputs work and you can't get a menu screen to show up, then it sounds like you may have a bad YSUS driver board.
Mar 21, 2014 | Televison & Video
Service menu exit
1) Does your service provider (TV company) have HD service to your house and do you subscribe to that option?
2) How is your box hooked to your TV? HDMI or at least Component cables are required to achive HD modes.
3) Does the Roku box have setting that determine the output resolution?
Nov 27, 2013 | Panasonic TX37LZD80 37 in. LCD TV TV/HD...
TV doesn't recognize HDMI with Roku
The Roku is the problem, not the TV. You need to go to the Roku site and request download information to synch the Roku to an HDMI input.
Jan 13, 2013 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sceptre TV unexpectedly changes input source away from HDMI
My sceptre tv just started randomly changing through input modes, sometimes once or twice before stopping and sometimes it continues
Jun 30, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 20, 2011 | Televison & Video
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
