Question about Electrolux Dryers
Electrolux model FEQ332CES0 spins but there is no heat. Any suggestions on why and how to repair the problem myself, thanks.
  • Electrolux Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Posted on Apr 11, 2015
I used the self clean feature & now oven does not heat
Hello friend, thank you for your post!
From my understanding your used the self-clean feature on your Electrolux oven and now it is not heating. This could be an issue with your control panel or thermostat. You may need to perform a reset on your range and you can do that by disconnecting power from it for at least ten minutes. If that does not help to alleviate your current issue with the range I would suggest seeking assistance from a professional technician for repairs. I hope this information is helpful to you. -Matt
Dec 30, 2015 | Electrolux Kitchen Ranges
WHIRLPOOL WASHING MACHINE WILL NOT SPIN SEE ADDITIONAL DETAILS
Sounds like your gear casing is broken inside, motor is spinning but transmission shaft where agitator sits on, is not spinning.
Apr 15, 2015 | Whirlpool Washing Machines
The tab that you push to dispense water snapped and is just hanging there. Can I fix this myself?
Good Afternoon Cecilia Soares, thank you for your inquiry!
From the information you have provided the dispenser tab on your Electrolux refrigerator has snapped and you would like to repair it. I am unsure if it is repairable you may need to order the replacement part for your refrigerator. Based off the model number, E23CS75DSS, I have located a parts manual this should help you locate which part may be needed. I hope this information is helpful. -Matt
Frigidaire Manual Search Results
Feb 13, 2015 | Electrolux E23CS75DSS Stainless Steel
Why Electrolux front load making knocking sounds during spin cycle. Model ewf1087
Good Morning Friend,
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Electrolux EW1200i Front Load Washer /...
How to repair roller on Vacuum cleaner
it migh be the belt.stretched and hardened from heat replace and try again
Feb 02, 2012 | Electrolux Vacuums
My Maytag Neptune gas dryer has stopped heating The button pannels turn on, dryer spins but no heat I cleaned the vents Model no. MDG6800AWW How do I fix it? Can I repair it myself? Is there a...
When the dryer wont heat it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help...
Dec 30, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Will not heat at all
Could be the "board". Well known for failure. Get the part number from the board & search eBay for NEW board.Instructions probably on youtube
Mar 05, 2018 | Electrolux Over-the-Range Microwave
G,day i have a electrolux dish washer model 302 that is not heating at all.where do i look for the heating element.Thanks
Hi Kanejake,
I'm Harvey the Master Plumber.
Your question is: you have a electrolux dish washer model 302 that is not heating at all.where do you look for the heating element?
First, check to see if the "air dry" button is on. It should not. The heating element is the blackish rail that runs around in the bottom of the d/w. I don't recomend this repair to homeowner. You might consider looking in the Repair Directory for a repairman. If the d/w has a few years on it you should compare the costs of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Electrolux Dishwashers
Dryers Logo
80 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
